Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I have an old Ultravision 50 inch projection TV. I have it connected to a cable box from Cox Cable. I am not able to get it to stay on a channel. I think I may have caused the problem when I mistakingly covered on of the Auto Link with my finger thinking it was the on/off switch. What happens now is, when I have the cable box on, a picture will appear just for a second, then the screen goes blank for a while, then the same channel will appear again. It is like it is sreaching all channels and only show one for a second. How can I reset or fix this? ****
  • Hitachi Master
  • 11,800 Answers
Actual if it's the one above it's not old at all, the technologies inside it are completely up to date. The Auto Link is designed to check all inputs and select the active one - you don't need it. To cancel its operation all you need to do is to manually select the source by pressing the Inputs button and then selecting the correct one.
First of all you must connect the Cox box to the tv using the 3 headed RCA cable (with Yellow, Red and White heads), not the antenna jack or the HDMI - this will disable all HDMI protocols and allow you to view the channel at a very similar quality. If even with the RCA cable you get the same problem then it's hardware, not software - most likely the control processor has difficulty detecting the presence of the signal - and for that the tv must be tested professionally.
Posted on Nov 17, 2010
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
My cable TV company is COX. I am getting the
Unplug,replug the cable box for an hour later.Let the box boot up,and upgrade the softwares.Might have go to ur tv menu to rescan all ur channels again.If this don't work call ur cable company might have to change the box.
Mar 30, 2010 | Protron PLTV-32 Television
We've had our 32" Vizio TV for about 4 months now and up until about 2 weeks ago, everything was working fine and all channels came in. Now, we only get about a quarter of the channels that we used to...
go to menu settings, find add/delete channel or programming or tuning. There should be an option that says "autoprogram" select this option and let the program run thuroughly. It will read and install all available channels. Do make sure tv is set to CATV and that it is NOT set on AIR.
Jan 27, 2010 | Televison & Video
How do i get it from air to cable on the tv it is olevia 42 inch
if you are subscribe to any satellite service provider, this doesn't work (ex. Direct TV), you can only get channel's thru your antenna when you are subscribe to a cable service provider (ex. Cox Cable or Time Warner Cable)
Dec 28, 2009 | Olevia LT42HVi 42 in. LCD Television
Hi, I connected internet cable (was just experimenting whether cox internet cable will get tv channel signal or not) to the antenna port of my mitsubishi 50" projection tv and tv's display turned off after...
LOL!!!!!!!!, your tuner is now faulty and maybe your Microprocessor as well, you will have to take it to a repairer this something you wont be able to solve sorry ......
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No sound on 3 channels
Check if the sound adjustment is in STEREO-SAP-MONO mode
Change to STEREO mode
Jun 02, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Sound loss
There is a software issue with the cox cable box. You television will only react to the input it receives from the box. Get cox to replace the box and not to tell you it is a problem with the television. Scrivitron
Jun 20, 2007 | Toshiba 35AF44 35" Rear Projection...
Panasonic PT-52LCX66...Connecting to HD
the TV is "automatically" HD. You probably have to turn to the HD channels (which sometimes require a subscription through the cable company. For example in my cable company there are 2 Fox stations, channel 10 with is NOT HD and then channel 810 whish IS HD
Jan 28, 2007 | Panasonic TH-50PHW6B 50 in. Plasma...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
