Question about Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers
I have tempurature in C instead of F . How do I change it back
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
You should be able to find your product's operating manual here:
http://www.chaneyinstruments.com/search.aspx?display=all
Posted on Nov 14, 2010
How do I change from C to F?
Posted on Sep 13, 2011
Room Tempurature on theomastat is not showing correct room tempurature
Sometimes thermostats Just go bad or are miscalibrated. Sometimes when it is on an exterior wall and it wont show the right room temp due to the wall being cold. Move to interior wall or replace.
Feb 15, 2015 | Heating & Cooling
Changed all vacuum lines including air intake hose truck still dies when temp at mid range with ac off. with ac on truck runs just barely should i kick up the idle and how do you do that ???
try by changing the coolant tempurature sensor. When this sensor malfunctions the symptoms range from poor engine performance to diminished fuel economy and engine shutdown. this sensor sends vital engine tempurature to computer,on most vehicles the check engine light will be on.
Jan 13, 2012 | 1993 Toyota T100
My 2003 ford focus station wagon over heats periodically. I will be running down the road and the temp will begin to climb. if I turn on the heat instead of air, the temp lowers significantly. Then the...
sounds like the thermostat is sticking!! and also you may have a bad coolant tempurature sensor thats not sending the right info to pcm ( powertrain control module ). good-day !
Aug 20, 2011 | 2000 Ford Focus
Ck engine lt on. p0128?
p0128 is coolant tempurature below thermostat regulating tempurature, the most likely problem is to replace thermostat. also be sure coolant is at proper level. if still problems, replace coolant tempurature sensor.
Mar 25, 2011 | 2003 Chevrolet TrailBlazer
My 2003 kia spectra comes up with P116 and P128 error messages. What do I need
p0116 is-- engine coolant tempurature ckt/range performance----- p0 128 is--coolant temp below thermostat regulating temperature. to fix these 2 codes are similar, change coolant tempurature sensor and thermotat all should be ok. make sure coolant in radiater is full. hope this helps you.
A code P0128 may mean that one or more of the following has happened:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
Feb 07, 2011 | 2003 Kia Spectra
Within five minutes, it starts to redline overheat, if you drive 2000rpm, it goes down, but goes back up when you idle
it could be a stuck thermostat, or a plugged radiator or cooling system, check to be sure cooling fans come on when they should or it will overheat. when moving it is air cooled through radiator. thats why it over heats at a stand still. check fans first, it could be a fuse relay or the coolant tempurature if fans do not work or coolant sensor not turning on coolant fans at the proper tempurature.
Oct 18, 2010 | 2003 Pontiac Montana
We need to know were the cooling fan control switch is located on a 1997 cadillac sadan deville.
The tempurature sensor sends the tempurature to the computer, and then the computer turns the fan on and off. Does the fans come on when the A/C is turned on?
Oct 18, 2010 | Cadillac DeVille Cars & Trucks
1998 F150 Hard to start when hot. Have to crank engine for 30 seconds. Runs ok after starting. Check engine says it is running lean. Starts ok when cold.
I have the same problem with my F150 4.6. Long cranking when out door tempurature is hot. Engine temp gauge indicates normal engine tempurature. Looking for solution.
Aug 21, 2010 | 1998 Ford F150 Regular Cab
Heat in car died after negative tempuratures, 95 ford taurus
usaly agood place to start is flush cooling system replace antifreeze if test fails on strenth,replace thermostat,and see where you are at this point
Dec 23, 2009 | 1995 Ford Taurus
Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers Logo
425 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
