Question about Canon PowerShot SX100 IS Digital Camera
My cannon powershot sx100 is says lens error and the shutter is not closing
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 15, 2010
I have a canon powershot sx100 IS the lens is
Here is a site that discusses things you can try to fix this for free. They do a much better job than I could, and they let you know the risks and steps to take, in order. Try this first, you might get lucky- they say 50% of stuck lenses or lens errors can be fixed.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Don't worry, this is a huge problem with extendable lenses, due to their construction with small, plastic gears that are easy to break with a bump or fall, or obstruction while extending.
Apr 18, 2010 | Canon PowerShot SX100 IS Digital Camera
My Canon Power Shot SX100 IS says lens error. restart camera. Help
Aug 24, 2009 | Canon PowerShot SX100 IS Digital Camera
I have the canon sx100 is, it dropped and now the shutter eye won't open
If only the shutter eye is not opening but the lens is extending properly, then you will need to remove the fron shutter frame and review it.
It may be that one (or both) springs that open the lens protector are loose, or the plastic tab that allows to open/close the lens protector is broken.
If the lens does not extend when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jul 18, 2009 | Canon PowerShot SX100 IS Digital Camera
Cannon sx100: displays lens error, restart camera
If your lens received impact damage it will need to be replaced. This is about a $150 bill at Canon. One thing that can happen is the flex cables that attach the lens to the camera system board may have come loose. You will have to have the camera opened by a qualified tech to see if this may be a solution.
Jul 02, 2009 | Cameras
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens Error
Unfortunately this Canon SX100 (and the SX110 too) has a very fragile lens assembly. Once you have this lens error problem, there are only four solutions: 1) If it's under warranty, contact Canon to make it valid; 2) If not, then have a repair center to replace the lens assembly (either the internal lens motor or the gears are damaged) or, 3) Sell it for parts or 4) send it to the trash can.
Jun 28, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens error, restart camera on Powershot SX100 IS
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 15, 2008 | Canon PowerShot SX100 IS Digital Camera
Cannon PowerShotA50 trouble
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 24, 2008 | Canon PowerShot A50 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
