Just wondering if I can upgrade my ASUS F5RL M/B to 3Gb or even 4Gb RAM as Vista uses a lot. Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
The manufacturer states a maximum of 2 Gb of RAM for your laptop. And if you have a 32-bit version of windows it may only recognize up to 3 Gb, even if you put in 4 Gb. I would recommend not using more than 2 Gb, as this is what Asus recommends, though I've seen laptops such as yours work just fine with more. You know it would work fine with 2... anything more would be taking a chance that it may not remain stable while operating. So it's up to you if you want to try. If it mysteriously re-boots with 4 installed it won't actually hurt the machine. It's just annoying when it suddenly dies and re-starts while you're using it, and then you'll need to remove one of the mem. cards to bring it back down to 2.
Posted on Nov 14, 2010
Blue screen with 4gb, OK with 3gb of RAM on 6720s laptop Using windows 7 (32 bit) there are 2x slots, but the top slot seems only capable of recognising 1gb of RAM without giving the blue screen at startup...
A 32bit OS and Processor is able to Identify and work with upto 3GB of memory.
That may be the cause of the issue
Even if any computer has more then 3gb of ram it will showup only upto 3gb.
if you install 4gb or more then also it will not show up.
.........and second reason, may the ram that you are using are not identical or one of them is not working properly.
Check the specifications of the ram and also try using one a time.
Thanks and Regards
Jan 03, 2010 | HP Compaq 6720s Laptop
Problem while upgrading my RAM
some systems require matching pairs, so since you are using mismatched, it may only recognize 1 GB of the 2gb module
Sep 27, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
My windows not shwoing whole RAM size
What you are seeing is correct. You have 4GB of physical RAM installed in the computer and it is being recognized properly by the BIOS. A 32-bit operating system can only address approximately 3.5GB of RAM. Vista may be rounding the number down to 3GB or if you are using on-board video, some of the RAM is being allocated for use by the video circuitry and is not reported as system memory. To see all of the installed RAM in your operaing system, you need to upgrade to a 64-bit version of Vista.
May 29, 2009 | Kingston 2GB Secure Digital Memory Card
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
OS not showing full RAM
Hi Shibbymusic, as with most Asus boards if not all! The MB
A8N-E does not show all of your 4GB memory. See this FAQ;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=A8N-E&os=17
Like you, I too have 4GB of memory.
Asus A8N32-SLI Deluxe w/4GB memory only see's 3GB
The bios displays 3GB during boot up & so does windows XP 32bit.
You might want to think about upgrading to 64bit os.
Updating your bios should help as well.
(See A8N-E Bios version 1010); http://support.asus.com/download/download.aspx?modelname=A8N-E&SLanguage=en-us
Thank you for using fixya!
Mike
Dec 07, 2008 | ASUS A8N-E Motherboard
4GB memory not being recognized
To recognize more than 3.5GB RAM you must use a 64 bit operating system
ordinary 32 bit O/S only recognize max of 3.25 to 3.5GB ram
Oct 31, 2008 | ASUS A8N-SLI Premium Motherboard
Maximum RAM not achiveable for KT4V
What Operating System and revision are you running?
I don't believe that XP 32bit (not sure about 64) will recognize 3GB of RAM, but Vista will as long as your MoBo (Mother Board) supports it or possibly even more than.
My Asus MoBo will utilize 4GB but Vista 32bit will only utilize 3.48GB or so, and Vista 64bit will take up to 8GB if the MoBo will.
Let us know what O.S. you're running?
Mar 12, 2008 | MSI KT4AV-L Motherboard
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
