Question about Refrigerators
I have a Maytab MTB2155BR Refrig that's leaking water. The freezer is on top and the water seems to be accumulating in the refrig section under the criper draws. Somehow it then leaks onto the floor. Have no idea what I'm looking at, but the compressor seems to be very warm - is this normal? Could this be my problem? The frig is about 10 years old and I'd hate to dump a lot of money into it only to have it fail again in a few years.
  • 868 Answers
Have you any tears in door gasket or do you see any way air is getting in the door through the door seal gasket?Is your temperature holding .Or have you had to turn it up??
Posted on Jun 18, 2008
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
Lots of water accumulates in tray under refrigerator. Must empty every couple of days.
You have an auto defrost drain line that is plugged up.Look behind the light and control shield in the fresh food section of your refrig., you should be able to see the problem.If you can not clean the line out from that point then you may have to move the refrig. out from the wall and get to it from there. I hope this helps and Thank You for using Fix ya
Jun 22, 2011 | Magic Chef CTB1722 Top Freezer...
My Refrig is collecting water in the bottom. My freezer is on top and the refrig is on the bottom. Water collects in or under the produce trays. What could be wrong
Without a model number or even a brand, this advise can only be general. You have a blocked defrost drain. Each time the refrigerator does an automatic defrost, the resulting melted frost needs to go down to a drain pain near the compressor, where it will evaporate. If the path to the drain pan is blocked, the water has to go somewhere, in your case, down the inside of the liner of the refrig and to the lowest level, under the produce trays. There may be a tube down the outside of the refrig on back which can be removed for cleaning, or the blockage may only be accessable from the area right by the cooling coils inside the freezer section. (usually located behind the back wall, but sometimes under the freezer section floor) You may find that flushing the drain tube using a turkey baster with warm water will be all that it takes to solve your problem.
Jul 14, 2010 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Water draining in bottom of refrigerator
Unplug the refrig . Inside the refrig section , remove the 4 screws ( 2 on each side ) and
lower the panel . Disconnect the large plug and remove the panel by pulling froward to
clear the defrost drain hole .Find a food safe caulking or odorless silicon and caulk at the
upper portion where the styrofoam meets the plastic AND on the top center of the styrofoam (
all the way around the large rectangle hole ) so that the styrofoam will seal to the top of
the refrig . When the refrig goes into defrost , the water is seeping between the refrig top
and the styrofoam , causing it to run into the refrig section . When reassembling , be sure
to plug the large plug back into the refrig .
May 28, 2010 | Frigidaire FRT21H8 Top Freezer...
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrig is Model ET8HKXM003 and Serial # E54044751 Manufactured 10/05. It is type 18TFA. The Temp is currently set on 3 (normal). The freezer appears to be leaking down into the refrig as I find...
the drain tube on the machine has frozen in the freezer section
remove the back panel and with a hair dryer thaw the drain tube
you will see an alluminum sheild with a 1/2 inch hole in the bottom of the shield this is where you want to direct the heat
it may take 20-30- mins to unfreeze it to make sure it is unfrozen pour som water into the valley of the sheild if it runs into the drain pan it is unthawed if it pools up keep unthawing
Apr 16, 2008 | Refrigerators
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
