Question about Ubi Soft Entertainment Blazing Angels 2 for Windows
When i start the game a black screen comes up. I have audio but no video at all!!! please help. I am running windows 7
My screen goes black when playing game
try this & see if it helps
Monitor settings for windows 7
1. Start menu
2. Control panel
3. Hardware & sound
4. Power options
5. Choose which settings you want & then go to the change plan settings
6. Choose which setting you want to run your monitor
7. Then save changes
Sep 10, 2012 | ASUS Computers & Internet
A black screen appears on my computer when i open nfs prostreet
To all the fellas that have a problem with running Pro Street on Windows 7 or Vista.(you know the black screen upon starting the game) It doesnt matter which build of windows 7,vista you Have. the sollution to this is to go to program files or which ever localtion you installed the game. Rename the "nfs.exe" to "nfsps.exe" and go to the Pro Street Icon on your desktop, right click and click properties. go to the target path and edit the "nfs.exe" to "nfsps.exe"
e.g: "C:\Program Files\EA games\nfsps.exe". Please note that this may not be the same target path as yours depending on which path you have installed the game.
Click apply and ok. then run the game.
note: this fix is only for gamers that encounter a black screen when starting the game in windows 7.
Jul 28, 2011 | EA - Electronic Arts Need For Speed:...
I have asus p5pe-vm motherboard system which i bought 5 years back with windows xp installed, after that a year back i installed windows 7 and i cudnt hear any sound from my system... as well every time i...
http://directx.en.softonic.com/
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 16, 2011 | ASUS P5PE-VM Motherboard
WHEN I START PLAYING TOTAL OVERDOSE IN MY WINDOWS XP A BLACK SCREEN APPEARS AND SHOWS "OUT OF RANGE:" PLEASE PLEASE HELP ME
yes minamino kitagami is right,
goto start menu ,
select Run
type in "dxdiag"
DirectX Diagnostic Tool will run
then click at "More Help"
you will see there Override tab in last just click it
after that "Refresh appears"
set it from default to override rate "60"
now exit.
and play the game enjoy.
Mar 21, 2011 | SCi Total Overdose for Windows
I tried to play a game on my computer and after i installed it and started to get ready to play it the screen turns blue, white and a band of rainbows come on the screen but the sound is working too??? not...
Most likely you do not have a video card that supports the game you are trying to play or an older game that may have been created for an earlier OS than 7.
You might try running the game in compatibility mode.
1) From start menu Click "Control panel"
2) Click "Programs"
3) Under programs and features click "Run programs for earlier versions of windows"
4) Choose your program and follow prompts.
5)Run in compatibility mode window will open choose "next"
6)Follow Prompts
Hope this helps you.
Jan 02, 2011 | Computers & Internet
When i run sparta exe the screen goes black and monitor starts blinking but game sound is still coming i m running the beta version of windows 7 buil 7000 help me
This usually happens when the game selects a video resolution, or frequency rate your monitor doesn't support.
See if there's any way to set the game resolution, some program to configure it, or even a text file with the configurations where you can manually edit it with notepad or something like it.
Also, make sure your computer fits the game requirements to be played (minimum requirements below):
  • Microsoft Windows Vista
  • Intel Pentium4 2.4GHz or equivalent
  • 512Mb System RAM
  • GeForce 6600GT / ATI Radeon X800Pro or better with 128Mb Ram graphics card
  • Direct X 9.0c compatible sound card
  • 4x DVD-ROM drive
  • 4 GB hard drive free space
  • Keyboard
  • Mouse
Also, Windows 7 is still beta, so that could be the cause of your problem entirely!
Mar 18, 2009 | Eidos Interactive Ancient Wars: Sparta for...
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Ubi Soft Entertainment Blazing Angels 2  for Windows Logo
636 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
