Question about Jl Audio 500/1 Car Audio Amplifier
I have a jl 500.1 and a 8w7. The sub is playing but not really it will play sometimes but most of the time i am getting almost nothing. Am i using the wrong settings or a bad connection or blown sub?
    Novelist:
  • 77 Answers
Sounds like a bad rca connection. You need both rca jacks to be plugged in from your head unit, both left and right or you will not have full power you'll have half power to your sub/subs. Check your sub with a volt meter and see what it reads. Make sure if your head unit has a sub volume make sure it's turned up. Alot of people don't realize they have a seperate subwoofer volume on there deck and it's set to low, so check that. You could have bad rca cables. If all that is ruled out(best way by trying a different amp) the amp itself might be having problems. Don't think it would be in protect mode either.
Let me know if you have'nt allready.
Posted on Nov 28, 2010
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
I have a JL total mobile audio T500.1 mono amp and it was playing then all the sudden it stopped and the power light which is usually green is now red and stays red and no sound comes from the subs any...
This happens when the amp goes into protection mode. 90% of the time, it means there is a short or has another issue inside the unit and has to be fixed or replaced. Hope this helps and good luck!
Jul 09, 2010 | Jl Audio Car Audio & Video
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Rca Connection
You need to check the shield ground on the head unit. The following link will guide you through the test procedure.
Shield Ground Testing
Jun 07, 2008 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 12W7
no repair kits available will work on any spl sub. JL will fix the sub for about 410$ plus shipping or i can sell you a new sub with warranty (JL factory direct replacement) for about $ 475 shipped
Jun 04, 2008 | Jl Audio 12W7 Car Subwoofer
System not playing
Sounds like the output transistors on the amp are blown. Were you slammin when it stopped or how did you find out it stopped working. It could be the sub failed then caused the ap to go which is why you get a little something from the JL.
Feb 11, 2008 | Car Audio & Video
Jl Audio 500/1 Car Audio Amplifier Logo
122 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
