Question about LG 42LD450 42 in TV
Help!! Switching on my LG 42ld450 when a box comes up 'Function cannot be used' then the TV switches itself off in around 20 seconds, it now keeps switching itself from on to standby?? Anyone know what has caused this?
    New Friend:
  • 112 Answers
Are you using the correct input setting for the device...HDMI, Cable etc etc.....it might be looking for the incorrect input
Posted on Dec 18, 2010
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
TV turns off by itself after 35 seconds of being on. Indicator light flashes red endlessly.
The TV is going into protection mode. Could be a problem with moisture. Can you try warming up the rear with a hair drier? Ensure that you do not apply too much heat to avoid damage to plastic parts. If you can remove the back cover (after unplugging the power outlet and switching off the TV), try doing in on the entire PCB, if you suspect moisture is the problem. Please do not touch anything in the board by bare hand as there would be high voltage charge in capacitors even after switch off. If it does not work, this might need attention of a qualified service technician
Jul 11, 2012 | LG 42LD450 42 in TV
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Jul 10, 2011 | LG 42LD450 42 in TV
I have the lg 42ld450 with 03.04.36 firmware. I want to unlock the usb port to play movies. I don't know how to access service menu. I have a dish network remote. Can anyone help?
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
Dec 30, 2010 | LG 42LD450 42 in TV
Lg 42ld450 is not turning on. It keeps flashing "red" in what appears to be the power saving mode. Any ideas??
The power board or power supply could be the likely cause of the problem. Have that checked out.
Jun 29, 2010 | LG 42LD450 42 in TV
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
May 24, 2010 | LG 42LD450 42 in TV
LG LCD TV model 42LH70YR switches on and off continuously
eduramagli@gmail.comHELP PLEASEEE!! I`VE THE SAME PROBLEM! MY 42LH70YR SI CONTINUOUSLY TURNING ON / OFF !!
PLEASE IF SB KNOWS HOW TO RESOLVE IT SEND ME AN E-MAIL. IM FROM URUGUAY
Oct 06, 2009 | LG Televison & Video
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
TV Switches itself off! JVC AV28WFT1EKS
replace c926, resolder components in the power supply
repair must be done by qualified repatr personnal
Jan 23, 2009 | Televison & Video
Philips 26PF4310 Keeps switching off when I power it up
it sounds as though your power supply went out
Oct 29, 2008 | Televison & Video
LG 42LD450 42 in TV Logo
222 people viewed this question
Computer Repairing
Computer Repairing
