Question about Dishwashers
Matag Dishwasher model MDB9150AWS dish racks have rusted out and need replacement for both top and bottom. Pleae advise on availability fo replacements, cost and complexity of installation.
alumaguy
  • 3 Answers
SOURCE: Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Posted on Mar 16, 2008
SOURCE: Our Maytag dishwasher, mod MDB9150AWS,
Yes, I resolved the problem after thoroughly studying the assembly. It was relatively simple; all I had to do was turn the spray tower 90 degrees and it came free of the rack.
Thanks for the web site, nonetheless.
Posted on Aug 28, 2008
larryyb
  • 291 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 360 Answers
SOURCE: Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Posted on Feb 06, 2009
  • 77 Answers
SOURCE: Dish racks for Kenmore Ultra Wash Model #665
www.Repairclinic.com is a great place to look. But from past experienc, dishwasher racks are very expensive and almost 1/2 the cost of a new one. Good luck.
Posted on Apr 21, 2009
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Dishwasher replacement part
Instead of replacing it you might try re-coating the rack with Plasti-dip. Available at some hardware stores.
Nov 15, 2009 | Dishwashers
Upper and lower racks of Beaumark dishwasher purchased in mid-1990s (model and serial number available) need replacing. Coating on metal racks has worn away and resulting rust is getting on dishes....
check with a local auto body paint shop. they might be able to sand blast them and powder paint them, better than new .or perhaps that stuff I see on TV FLeX COAT spray or brush on rubber coating
Dec 15, 2017 | Dishwashers
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Our Maytag dishwasher, mod MDB9150AWS, has abad lower rack due to rust and prongs coming loose. Maytag sent me a replacement BUT without the center spray tower. It looks like trouble to remove the old...
Aug 27, 2008 | Dishwashers
Rusty dish rack
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Kenmore built in mf#15254
check the sump screen and make sure theres no obstructions.are the wash arm holes clogged?is the drain hose clogged?
Aug 13, 2007 | Kenmore 24 in. 16293 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
