Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
The water tank on my bissell proheat 2x is not keeping the clean and dirty water separate. I;ve checked the container and there doesn't seem to have anything wrong with it. Also when I switch the machine on you can see the "washing" action, after a few minutes this seems to stop - there is water and forumula in the machine. Only had it a year!
SOURCE: Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Posted on Jan 14, 2009
  • 25 Answers
SOURCE: bissell 2x wont **** up the dirty water
My machine would not **** up the dirty water either. I tried everything, read the "troubleshotting" section in the manual and nothing worked. Then I discovered there is a little FILTER that is not mentioned anywhere and is hard to see. It was clogged with dog hair. It is in one of the two removable sections on the top of the machine. It is NOT in the bladder section but the section with the dial to switch from floor to tool. It is red and about 1 inch long. There is a little door on it that you flip open (it actually looks like you can remove it). Flip the little door open and you will probably find a bunch of gunk. Remove it and the machine should work perfectly. Mine now does! Good luck.
Posted on Sep 12, 2009
  • 33 Answers
SOURCE: I have bissell proheat 2x 9200 no water or
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell 9500 Proheat 2X won't dispense fluid.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgjhdjk
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell Proheat 2x TurboDoes not pick up the water after cleaning
heatman101
m,nb
Bissell proheat 2x 9500e leaking water
Hello, this is Ava with Think Crucial.
First, make sure that the caps are on securely and the red rubber auto-load gaskets are in place. If the red rubber auto-load gasket is missing, check to see if it's stuck in the reservoir. Next, check the tanks for cracks or damage. If there is damage then you may need to replace it. If your gaskets are correctly assembled and your tanks don't seem to be damaged, at this point it might be best to take your carpet cleaner to a technician. You can call Bissell at 1-800-237-7691 for authorize service center near your area.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Think Crucial Customer Care
Jun 22, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a blue bissell preheat 2x. While shampooing it will start to leak dirty water. When i'm done shampooing my carpets look even more filthy then when I began. Not sure why this is happening besides...
You should drain the dirty water, you should find where it is stock then drain it. If there's some leak, seal it with an epoxy. Thoroughly clean the inside and you will find there's a stock of old shampoo which causes water to become dirt.
I hope my advice help you.
Jul 13, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x pet won't spray water or **** dirty water up
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Feb 13, 2011 | Bissell ProHeat 2X CleanShot Bagged...
My Carpet cleaner isn't sucking up the dirty water. Squirting out the clean water and cleaner just fine. What's wrong?
Fairly common problem... inside the dirty water container there is a red flap that has a filter, clean it off and you are good to go.
Zashiban
Jun 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
heatman101
m,nb
Nov 20, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
37 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
