Question about Bugaboo Frog - Black Stroller
The brake is locked on full, how do i take the brake off?
    Guru:
  • 541 Answers
You have too much tension on the cable. When you press the brake button the lever has to move sightly forward to disengage the ratchet teeth. Try pushing the lever on a bit more as you press the button. If that doesn't work check the cable adjuster at the end of the cable, if it can be wound down a bit that would help. If this all fails take out the two screws holding the break lever to the handle. It's a very simple mechanism of a lever, release button and spring. The ratchet teeth are on the outer edge of the button and the inside surface of the handle. Once working give the whole brake system a good coat of silicon spray. Lubricant won't effect the toothed brake system of a Bugaboo but wear on the teeth does!
Posted on Nov 14, 2010
Brakes keep locking up after a short distance. Dr
check that the callipers are free to self centre on the slides .
replace the master cylinder
check that the master cylinder reservoir is not over full
the problem is that the hot expanding fluid has no where to go to expand so it applies the brakes.
Apr 22, 2015 | Cars & Trucks
How I fix my brakes after they've locked up??
can be several causes. Faulty master cylinder , binding wheel cylinders, faulty brake hoses , oil on brake linings, binding brake adjusters , faulty brake booster. Best to take to a brake repair shop. Or buy a workshop manual and a full set of tools including safety stands and floor jack.
Apr 03, 2015 | Cars & Trucks
1988 Chevy scottsdale front brakes locked up brake fluid full help
If your brake hose collapsed internally that will cause brakes to lock to be sure its the hose and not the calipers open the bleed screw and see if the rotor release. If they stay locked then maybe calipers seized try to pry brake pads apart with caliper mounted and brake bleeder open if they return easy then change your brake hose.
Mar 04, 2015 | Cars & Trucks
2006 chevrolet malibu find out my anti lock brakes had been cut none on front what do i do . does this mean i have brakes or what will a booster help this or what do i do please help
If you have no front brakes working, check master cylinder fluid level .If full replace master, if fluid low or empty check for broken line or leaking caliper..if your anti lock light is on but brakes are working ok your anti locks will not work but regular brakes will be ok. If this was helpful please leave good feed back.
Aug 02, 2013 | 2006 Chevrolet Malibu
Front driver side brakes locking up
i replaced the caliper and then the caliper brake hose, and i drive it 3 to 6 miles and drivers side hangs up again, let it set for about 20 minutes and then i can drive it another 6 miles before it hangs up again, new brakes, new caliper, new hose, so what is making my front drivers side brake hang up?
Sep 09, 2012 | 2005 Chevrolet Aveo
2003 hyundai accent brakes lockup,had calipers,hoses pads and drums replaced still locks up
Who ever replace them, make sure they bleed the lines. This could create air in the lines if they were not bleed. The air could make them lock or pulsate.
Nov 28, 2010 | 2003 Hyundai Accent
What does it mean whan the right reer tire locks and will not move when it is shifted into both drive and reverse?
If
you have pads on the back then the calliper is seized.If you have drums fitted the the shoes are locked to the drum.Cylinder seized or linnings come away from shoes causing brake lock up.Hope that was help full good luck.
Jul 28, 2009 | 2005 Ford Focus
The brakes klick on full rotation of the wheel?
check the cvjoints--they are the things that click on full lock(rotation)
Jul 11, 2009 | 2002 Mini Cooper
Bugaboo Frog - Black Stroller Logo
518 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
