is it stick shift or auto box???
for stick shift check the clutch is working and the drive shafts are good
if the half shaft if snaped the prop shaft will turn but the car wont move!
if its an auto box check it is full of oil as well and then check the gear shift is working some times they just fall off,,,,,if the prop shaft is turning and the car wont move the fault is in the rear axle (drive shafts snaped)
Not familiar with this Camera, but does it have an Auto Flash setting which you can set so the camera will decide if flash is needed or not try this if it is available and see if that helps.
I think your balljoints in front are bad. On 4x4 I repaired recently, both of them where bad and it had a lot of vibration. I'm guessing it doesn't happen when it's only in 2wd.
The cables that are running the window have snaped. You can get a rep[lacement window regulator from the dealer or check out a company named dorman they have them for lees then half price of the dealer
