Question about Brother GX-6750 Typewriter
When I replaced and snapped the correction tape correctly onto the white nylon holder, without turning the typewritter on, the feed spool spins on the and the tape unwinds. Is something on the holder broken because it appears that the geared base isn't connected to anything.
  • 453 Answers
Are you sure it is the right lift off tape for your machine or that is securly snaped into place
Posted on Dec 12, 2010
How do you get the string to come out of the spool whilst the snipper is in use ?
There are two or more types,
1: provided the spool is full and wound on correctly, to increase the length of nylon you tap the head of the snipper on the ground while it's spinning. This should release extra cutting string.
2: others are simply feed by the centrifugal force governed by a spring in the head. When you wrap the nylon string around the spool, then feed the nylon out the holes provided, the weight of the nylon string pulls the required amount of nylon out so you can continue to work.
Others are manual, simply pull the nylon out by hand to the desired length.
Note that you are only cutting with the very tip of the nylon string, not the full length.
Mar 29, 2015 | Garden
CORRECTION RIBBON
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Office Equipment & Supplies
How to install correctronic ribbon
Open top cover, small correction tape orange or yellow lift off is kind of tricky, left side goes on small spool holder feeding off the top and going around front of print wheel. by the way relaase the printwheel so it pivots back toward you, eaiser to see, correct tape goes in front of wheel and pivots very similar to left side. Correction tape has good side and bad side good side a matte finish should face away from you, this is the correction. Regular riboon just lifts up reom the front and snaps back in place. two little plastic tabs on back of ribbon case fits in two little holes in carrier. Hop this helps real hard to describe.just works...
Sep 29, 2013 | Brother Gx-8250 Correctronic Electronic...
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Trying to replace the lift-off tape on an IBM Selectric III
Open the gray lever to the right on the carrier.this will release tension on the correcting tape. Now put the supply spool on the left side and bring the take up spool across in front of the card holder. There is a little black wire just right of the card holders opening that looks kind of like a bobby pin , this is the
separator between the ribbon and the correcting tape.The ribbon is in front toward you and the correcting tape is behind. Continue feeding the correcting tape to the take up wheel and take up the slack in the tape then close gray lever.
Mar 24, 2009 | Office Equipment & Supplies
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Changing correction tape on swintec 2600
Be sure the corr. tape not a tacky kind, then type some thing and correct it watching the mechinism th see which one turns and in what direction. Install the empty spool on that hub thread the L/O thru the guides with dull side facing the paper and then the full on the supply hub. there may be two or more guides depending on the printer.
Hope this helps
DickyO
Apr 28, 2008 | Office Equipment & Supplies
Typewriter change correction tape
I just finished replacing mine..You must first remove the ribbon for the typing, this simply lifts off. Then you must place the side with the corrective tape on the left side and the empty end on the right. While doing so, make sure that the ribbon of corrective tape is being placed around the knobs( one on each side) to hold in place. Then feed through and wind up till all the orange has disappeared then replace the Typing ribbon and this should complete the replacement
Apr 07, 2008 | Office Equipment & Supplies
Brother GX-6750 Typewriter Logo
83 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
