Question about Starbucks Saeco Italia Digital Barista Coffee Machine
My machine is getting the waste coffee stuck to the screen inside where it brews, it doesnt make pucks any more they are loose
  • 1,089 Answers
Hi
Turn the + / - knob in the bean hopper to the + and then back 1 mark. Are the grounds coarse or fine? They should be like coarse sugar through your fingers. If they are very coarse that can be part of the problem. What is your setting on the big knob. It should be around 8 depending on your bean. Only turn the big knob down when the grinder is grinding. You can turn it up any time.
Posted on Nov 14, 2010
  • 1 more comment
  • mattyblazer Nov 14, 2010
    Looks much better, thanks, the machine is getting old, it was set up around 14, I think that was making it too fine.
  • bansheracer Nov 14, 2010
    Hi
    14 is to coarse. I have one of these with over 18,000 coffees. Smaller numbers are finer, and larger numbers are coarser. Coarse grounds leave air space for water, and low coffee dose leaves more air, for more water.
    Sounds logical to me, well the 8 setting worked better, the drink came out stronger, and the pucks are firmer, the higher setting was making a mess in the brew group.
    Thanks
Coffee rounds in tray after brewing
is just normal after you brew coffee that the used coffee pucks get off the machine
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Hi, my saeco vienna plus has wet coffee grinds. When I went to empty them out it was like a water and coffee grind mixture.
I am not familiar with this problem. It would seem that the brewgroup does not function correctly.
Take the brewgroup out and clean it carefully. Inside you will see several more or less vertical grooves in which the mechanism does its work. Put some vaseline into these grooves, sothat it moves more easily. Mind: ONLY vaseline is allowed! This may help. It is a good idea to do this at regular intervals anyway. Good luck!
Jun 09, 2014 | Saeco Vienna Espresso Machine
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
I just cleaned our the brew group of my Saeco Vienna Plus and I unscrewed the screen and cleaned it also. Now when I brew, I am getting a puddle of water in my grounds bin along with the grounds puck. I...
First, I'm NOT a Saeco technician, But I have worked on similar machines. It's odd that you had to clean the screen of the machine though I'm not sure it this is a recommended procedure as these home "super automatic" are a ROBOT espresso maker. Yes on large espresso machines the group screen is easily removed for daily or at minimal weekly cleaning. There is a screw in the center which is easily removed and screen is brushed till clear of grounds.
* I'm surprised that you can access this screen. But since you have already done so then I guessing you disassembled the piston
assembly (the part that squeezes the grounds to form the puck.
* Okay, The group usually has a number of gaskets (or O-rings)
and I can see from the "Gasket Set"
https://www.bing.com/shop?q=+Saeco+Vienna+Plus&FORM=SHOPPA&originIGUID=202322DD03D24C3DBC248AAE69EBE4D6
There are quite a few gaskets. Now since these are available on line I'm guessing they have been made available to those willing to replace them. So maybe your okay.
* I suspect one or more of the gaskets are not sitting just right to make a proper seal. It's either broken or not in place. Thus the group leaks and water is probably leaking past the piston and leaks on puck after it dumps.
* There is another possible problem (watery pucks) is that the piston is not compressing the coffee into a proper puck. It needs to squeeze the grounds down to restrict and slow down the hot water giving it enough time to extract the coffee essence from the grounds. If your getting weak coffee and watery, loose pucks then it's the piston. This could be caused by a misplaced compression spring or that loose gasket getting in the way.
* I would normally suggest you calling for service. But Since you have already taken this unit apart (and I Don't know about the warranty) You may have to carefully work your way backwards on what you did to see if anything is missing or loose. Go all the way back to where you think was the end and look around. Put it all back together and try again.
* Okay NOW I remember this machine! It's on youtube BUT I'm cringing as I watch it! Really don't like this machine (Sorry) I had 15 come into the shop and only got 3 to work. Way too many sensors and safeties. I still got an old one in the garage that worked for a month then stopped for no reason. Okay here is the link Good luck!
Aloha, ukeboy57
https://www.youtube.com/watch?v=xGIK-lc__dw
Jan 14, 2018 | Saeco Vienna Plus Espresso Machine
Can't have two coffee in a row...
I had the same symptoms, except in my case coffee would sometimes not be produced irrespective of whether 2 coffees were selected. Over a period of a few weeks the problem gradually got worse. When coffee was not produced, the coffee grinds in the waste container would be dry, indicating that hot water was not being forced through the puck. The problem in my case was the o-ring on the back of the brew unit was no longer reliably sealing the path from the hot water pump through to the puck, resulting in the hot-water being expelled directly into the drip tray and no coffee being produced. To fix, I removed the brew unit and replaced the o-ring on the back of the brew unit (3 minute task). Note: This o-ring is the most stressed in the entire system because it must withstand the high pump pressure as well as being inserted/removed from the hot water outlet each time a coffee is made. No other seal has to perform this task and Miele have obviously used a very high quality o-ring because this lasted 11,000 coffee cycles in my case. I would strongly advise you buy the Miele o-ring (about $4) and to also regularly cover this o-ring with the Miele grease (or other similar food grade grease). Also the old o-ring looked fine but this is deceptive. On close inspection I could see the old o-ring was a flattened on the outer edge and this was enough (given the high pressure required to force the water through the puck) to allow water to get past the o-ring and bypass the puck. In retrospect, there were other much earlier symptoms of the failing o-ring. Firstly when the brew unit was removed, the opening in aluminum panel to the brew unit drive would always be soiled by wet coffee waste, caused by coffee waste being forced back down the hot water pipe and escaping past the 0-ring seal (Note: Miele have designed the unit so that when the o-ring fails the water and coffee still return to the drip tray however it still creates a mess in the back of the machine. If it's really dirty then you need to remove brew unit drive fro cleaning and that is a significantly more complex task). The other symptom was that the coffee taste was not ideal and this is caused by the insufficient pressure being reached during extraction. So once I replaced this o-ring the coffee taste improved and the back of the machine was bone dry. I suspect Miele replace this o-ring every time they service these machines irrespective of symptoms because the cost is low and the impact of a failed (or failing) o-ring is significant. Regards
Nov 16, 2013 | Miele CVA4070 Coffee Maker
Saeco Vienna superautomatica won't dump grounds puck into dump box
This needs looking at by a Saeco repair shop - the brew unit travels in a distinct 'pathway' from being empty, to filled, to coffee being tamped, then to being emptied. Yours is obviously not working as intended.
It may be the brew unit needs lubricating ( NOT OIL) or it may be the gear system that drives the brew units movements that needs attention.
Cheers
Mike.
Nov 14, 2017 | Saeco Vienna SuperAutomatica Coffee...
Coffe is too watery, and pucks are very loose
Try adjusting the grind finer. You have to do this while the grinder is running, Try 2 numbers towards fine. Then you will have to brew 2 coffees to get a reading on your adjustment.
Mar 02, 2011 | Saeco Incanto Classic Espresso Machine
Brewing cycle and upper filter?
Be sure your metal strainer in the coffee puck funnel isn't clogged. Check you grind level adjustments also.
Best Wishes,
Lane
Sep 20, 2008 | Solis Master 5000 Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
226 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
