Question about Zanussi ZBQ665 Electric Single Oven
Zanussi oven wont work. clock flashing 'auto'
Clock flashes and oven wont switch on
  • 2 more comments
  • saxa Jun 19, 2008
    I dont have the instruction book. Can you give me a brief explanation.
    thanks
  • saxa Jun 20, 2008
    tresilla, that worked fine.
    Many thanks
    Saxa
  • Anonymous Mar 25, 2014
    Oven clock flashing zeros and auto-timer symbol also flashing. Handbook instructions about setting clock not working.
  • Anonymous Mar 31, 2014
    the oven is on automatic and is showing a flashing sign - I want to switch it back to manual using the knobs provided but don't know how
    President:
  • 1,462 Answers
You need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
  • douglas smith Jun 19, 2008
    this is from memory
    hold in 1st and 3rd button and you can set time by turning rhs button(doesn't matter what you set it to)
    turn on oven so you can see it works. press button with wavy lines under it and oven should spring to life
    you may have to experiment a bit
I cannot get the big oven on my belling db90 to switch on. the clock is flashing 00:00 auto
Set the clock to manual....a hand symbol..... then try again....the oven wont work on auto unless you set time on and time off
Oct 06, 2017 | Belling Ovens
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
My zanussi ZBS773 wont switch on, the clock is showing and the wrong time and the decimal points are flashing, not sure if this is something to do with the timer, but that is showing 0.00. Not sure what...
If numbers are flashing press button "-" or "+" .When the correct time is displayed confirm the setting by pressing the square button with a "c" on. The clock will start runnning.
If the numbers are static press buttons l-> and l-> in at the same time and hold both of them in until the numbers start flashing . Release buttons l-> and ->l
then adjust the time by pressing "-" or "+" and confirm by pressing the square button with a "c" on .
Apr 11, 2010 | Zanussi ZBS963X Electric Single Oven
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Oct 20, 2008 | Neff B1421 Electric Single Oven
Zanussi zbf 760
Gently but firmly pull one of the other buttons out and use that to reset it... you can buy new buttons on ebay
Oct 03, 2017 | Zanussi ZBF660 Electric Single Oven
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZBQ665 Electric Single Oven Logo
1,401 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
