Question about Ovens
Hotpoint oven thermostat replaced again a few months ago now oven working but thermostat bulb not. Can this be replaced and how ? Thanks
  • Ovens Master
  • 3,463 Answers
Depending on which thermostat you are talking about , the main oven thermostat is complete with with sensing bulb, so is replaced as a complete unit.
The other stats, including over heating stat, and cooling fan stat do not have a sensing bulb, they are a bi-metal device, and can be replaced individually.
Posted on Nov 14, 2010
My hotpoint oven is burning everything so need to know what to replace
If your oven is burning everything, it is getting too hot. Therefore the heater is working but the thing that measures the temperature is not. This is called the thermostat and there will be two types, one for each oven.
Google search for Hotpoint UY46 thermostat, there are plenty of suppliers. Make sure you get the correct one for the oven that is burning.
They are about 20-30 pounds to buy and generally easy to change. Just make sure the power is turned off before working on the oven and be careful of sharp edges as it is easy to get cut when removing panels.
Good luck.
Sep 01, 2014 | Hotpoint UY46 Style Line Stainless Steel...
Both oven lights out
Are you buying hi quality oven grade lamps for this purpose that'll take the intense heat inside an oven? I wonder if they're halogen or tungsten filament lamps. Defective solder, frosty joints and/or ring fractures on lamp driving areas of a circuit board ARE indeed capable of causing problems with lamps.
Mar 16, 2014 | Dacor MCS130 Millennia Electric Single...
The oven cannot keep a consistent temperature. It is mostly about 100 degrees above the selected temperature. My landlord replaced the stove about a month ago and the problem is worse now than it was...
It sounds to me like the oven thermostat is faulty, as this is what controls the temperature.
If you can , get a thermometer and place it in the oven and check the temp against the seting with the thermometer, if as you say it is 100 degrees above setting , then you need to replace the thermostat.
Feb 06, 2011 | Hotpoint Ovens
Jenn air wall oven control panel not working properly
You will need to replace the front control board and the touch panel
Mar 28, 2017 | Ovens
Hotpoint BS22 oven. There's no heat from the element, but the orange light on the front comes on to say that its trying to heat up. I replaced the element a few months ago, so is it likely to be the...
My guess is it is the element gone again, to be certain , you need have it tested with a meter, if it is o/k, then it could be the thermostat, or perhaps a bad connection.
Please rate my solution.
Thanks.
Nov 11, 2009 | Whirlpool GBD307PR Electric Double Oven
Hotpoint lp gas range Mod# rgb532bea5wh. Oven will not light. Igniter does work but no gas is passing thru the oven control valve. I replaced the oven control valve but oven still does not work. what else...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective pressure regulator(likely issue if the igniter is ok)
Oct 23, 2009 | Hotpoint Ovens
Oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Thanks.
Jul 21, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Ovens Logo
109 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
