Question about KDS Valiant 671DP Notebook
Dim Monitor The desktop icons are not visible; however, when I connect the laptop to another monitor, the icons are visible.
    Genius:
  • 2,028 Answers
It sounds like the screen inverter is going out. The inverter works in this way: The power supply cuts the amount of power going into the board down, however the screen needs more power to enable it to function properly, so the inverter boosts the power back up to a level that the screen needs. If the inverter starts to go out it can create a multiple amount of indications that are noticable on the screen, one of them is darkening of the screen. It could also be the screen itself, but I'm leaning towards the inverter.
Posted on Jun 18, 2008
Dark screen
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 21, 2012 | Toshiba Satellite E105-S1402 Notebook
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
All typeset and pictures have shadows/blur have changed out video card on Lenovo computer - seemed successful for a while but now back to square one. any ideas
Try a different "data" cable between the monitor and the computer.
Connect the monitor to a different desktop/laptop.
If the "shadowing" is still visible, then it's the monitor that has gone "bad'.
Connect a different monitor to your Lenovo computer.
If the "shadowing" is still visible, then your monitor is OK, and your video-card is the problem.
May 18, 2010 | Lenovo ThinkVision L192 19" LCD Monitor
Computer monitor is dark -- no desktop
Try to connect your computer to another monitor and reinstall your graphics card. In parallel, try to connect your monitor to another computer and check if it is working properly.
You'll know for sure who the culprit is.
Apr 17, 2010 | Computers & Internet
Hp laptop is has docking station connected to acer monitor. The acer monitor has the desktop background but does not show desktop icons. How do I get the icons to show on acer monitor
you will probably find that you have set the screens to run side by side, do a check by clicking the identify monitors, icons will be normaly on the left screen, check the dispay settings and you probably want to set the monitors so they both are showing the same screen at the same time.
good luck.
Jun 30, 2009 | Acer AL2016W 20" LCD Monitor
Connect a soyo desktop monitor to my nc8000 notebook
Are you able to drag items over to the other monitor? Such as a window or desktop icons?
May 16, 2009 | HP Compaq nc8000 Notebook
Laptop screen has vertical black and white stripes
when you hook up the external monitor did you hit the fn key and f5 this should turn on the external monitor port
Apr 12, 2009 | Dell Vostro 1000 Notebook
KDS Valiant Laptop - Dim display.
Right click on the desktop, select view, then select show desktop icon.
Jun 30, 2008 | KDS Valiant 671DP Notebook
Connecting samsung monitor to my laptop
Assuming you are connecting the mointor to DVI or VGA cable. You can connect the monitor through windows. In vista, right click, personalize, display settings, You should see a greyed out monitor. Click extened the desktop onto this monitor, It should automaticaly detect itself.
In xp its similar. Right click on desktop, go to properties. You should see a screen pop up. Go to the last tab. it should be monitor. Click on teh greyed out area and click Extend the display to this monitor.
May 30, 2008 | Acer TravelMate 4200 Notebook
Don't know what to do !
connect external monitor to see if adapter is ok. If external monitor comes on OK,(check to see if the FN+F5 or another key has to be toggled for external display) then shine flashlight on screen to see if Icons are visible. If the Icons are visible LCD inverter would have to be replaced. If external monitor works and Icons are not visible lcd is probably no good, If external monitor does not work then Video adapter is bad.
Apr 05, 2008 | Compaq Armada 1750 Notebook
KDS Valiant 671DP Notebook Logo
94 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
