Question about Ricoh Office Equipment & Supplies
Nasuatec copier mp5000 error code531 - Ricoh Office Equipment & Supplies
  • 165 Answers
SC531: Fusing/duplex motor lock
-Definition- [C]
A fusing/duplex motor lock signal is detected for more than 2s during rotation.
- Possible causes -
• Fusing/duplex motor defective
• Too much load on the drive mechanism
• Poor fusing/duplex motor connector connection
• IOB defective
Check the fuser make sure its running free and the duplex 2
Posted on Nov 14, 2010
What is the solution of error code sc220
Sc 220. For the earlier model..it refers to the polygon motor error. U cannot clean the motor. U have to replace it. Becauce the sensor did not detect suficient optimal RPM
Aug 17, 2014 | Ricoh Aficio Mp5000 Lanier Ld050
Ricoh mp5000 error code sc220?
1) The Copy Data Security Unit card not installed
2) The Copy Data Security Unit card is installed, but it is not the correct type for the machine.
Oct 02, 2013 | Ricoh MP5000
Error message sc.440 on ricoh mp4000 copier
It happen when there is a slight load tansfer belt. What l did was..clean all the rollers & bushings underneath the transfer belt. Threre are 3 rollers..4 bearings & 2 bushings. Remove all stains.. And also you could polish the surface of the transfer belt by using car polish liquid to smoothen the belt rotation
Jun 28, 2013 | Ricoh Aficio Mp5000 Lanier Ld050
How to reset cleaning web replace service call aficio mp5000
Enter in the service menu : intr.key(yellow) - 1 - 0 - 7 press and hold Stop/Clear(red)key ,enter in SP mode ,counter mode ,reset the present part life counter.
Jan 22, 2013 | Ricoh Aficio 2015 Copier
Sc819 trouble/error in ricoh aficio mp5000. any help? thank u
SC819: software error. upgrade controller to the latest version. Faulty RAM and ROM DIMMs also cause this problem.
Ricoh Errors
Jun 02, 2011 | Ricoh Office Equipment & Supplies
Nasuatec 5000 web roller reset how
uplug copier for a few min. and plug back in.
Feb 14, 2011 | Ricoh Office Equipment & Supplies
Ricoh jp 5000 errore code message ec 5-51
Its a MP5000 right??
You have Loose connection of pressure roller thermistor.
Try this:
Press the clear mode key (yellow key)
Use the keypad to enter "107"
Old down clear/stop for at least 3 secounds (red key)
Enter the service mode (on the touch screen press "copy mode")
Exit all the way to return to the copy window.
Turn the machine off/on.
If doesn´t work you have to call technical assistence.
Feb 12, 2011 | Ricoh Office Equipment & Supplies
My nasuatec dsc 435 displays sc 440-02.I don't know what to do
That code is color drum motor lock (cmy). 440-1 is for black. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
Jun 15, 2009 | Ricoh Aficio CL7100 Printer
127 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
