Question about Smeg 24 in. DWD612SS Built-in Dishwasher
The program and start buttons dont work and the light remains on "end"
  • joecopski Nov 16, 2010
    I have tried both of those things already.
    My dishwasher must be a different model, the two buttons are a program button and a play/pause button. Pressing them together does nothing. It's as if the buttons are jammed in.
  • Smeg Master
  • 3,247 Answers
It is likely the moisture has got into the keypad or the controller has frozen.
Have you tried to turn the power off and on again?
Also try pressing p1 and p2 buttons together.
Posted on Nov 14, 2010
  • Sam Nov 16, 2010
    PLease confirm if the model is similar to the one in this user manual.
    The program keys and start button connect to the display pcb which must have got a fault.
    This needs to be opened up and cleaned and tried. Make sure the dishwasher power is turned off when working on it. If cleaning and reconnection does not work then you will have to replace it.
    This is the best solution and this stage.
Woods in-wall timer
If Woods 59028 timer turns on-off, then it is probably wired correctly, assuming white wire is connected to neutral or ground as shown on following link.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Lights turn on-off with override button, so timer is probably not beyond rated capability.
That leads back to programming.
Before beginning, always reset timers to clear out possible conflicts.
Next, program carefully so there are no programming conflicts or overlaps,
Make sure that each ON has corresponding OFF, and that selected day(s) match for both ON and OFF.
Woods 59208 timer has 1 year warranty for defects in workmanship.
Buy timers at local box store so returns are easy ... you can buy new timer and return defective timer in new package long after warranty period expires ... giving yourself free extended warranty.
About 4% of new timers arrive defective.
Aug 09, 2012 | Woods 59028 Programmable Timer Switch...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
I can not program my universal RCA remote to my JVC DVD player. I know it can be done, because it was programmed before. I do not what I "hit" or"pressed" to make it stop working....I...
If you cannot locate the code for your device, try the code search method below:
Step 1: Turn on the device.
Step 2: Press the "CODE SEARCH" button until the indicator light illuminates, then release.
Step 3: Press and release the VCR, TV or Cable button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5: Press "ON/OFF" repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button a few hundred times if your code is towards the end in the list.
Step 6: When your device shuts off, press and release the "ENTER" button.
Step 7: With your device on, press a frequently used button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test. If it does not function correctly, repeat steps 1 through 6.
Auto Code Search Step 1: Turn on the device you want the remote to operate.
Step 2: Press and hold the "CODE SEARCH" button until the indicator light illuminates, then release.
Step 3: Press and release the device key that corresponds to the equipment you want the remote to operate (TV, VCR/DVD or DBS/CABLE etc.). The indicator light blinks once and then remains lit.
Step 4: Aim the remote at the device and press the ON/OFF key once. The remote automatically sends every code for the specified component one at a time, with a a few seconds delay between each code. Keep the remote aimed at the component throughout the process.
Step 5: As soon as the component turns off, you must press the "ENTER" button immediately for the remote to store the correct code. If you don't press "ENTER" within a few seconds, the remote will send the next code in the list and you will have to start over from Step 2.
Step 6: Use Code Retrieval described below to identify the code for your device for future reference.
Code Retrieval If you used one of the "Code Search" methods to program your universal remote control, follow the steps below to find out which code is compatible with your device. Finding the actual code and writing it down will save you a lot of time if you ever need to program the remote again.
Step 1: Press and hold the "CODE SEARCH" button until the indicator light turns on, then release.
Step 2: Press and release the device key that matches the equipment's code you are retrieving (TV, VCR/DVD, DBS/CABLE, etc.). The indicator light will blink once then remains lit.
Step 3: Press and release the "CODE SEARCH" key. The indicator light will turn off.
Step 4: Starting with 0, press the number keys in order (0-9) until the indicator light blinks.
Step 5: The number that causes the indicator light to blink is the first digit of your code.
Step 6: Repeat Step 4 until you have retrieved all 3 numbers of your code.
Nov 04, 2010 | RCA 4-Device Universal Remote
Setting timer to start the brewing of coffee ...dont have the manual on how it set it
First, press the PROG button. Now it's in PROGRAM mode. While the light is flashing, use the HOUR and MINUTES button to set the time you want the machine to fire up and start brewing. When you're done, just press no buttons for a few seconds till the light stops flashing. That ends program mode, and you're all set.
Write me at KM7005@flightsystems.biz if you need more help.
Jan 14, 2010 | Krups Small Appliances Espresso Machine
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Media and volume lights issue
use your recovery disk that came with your computer to reload all drivers and functions to this computer back up your hardrive first because this will will erase all non OEM programs, saved data and printers.
Jan 13, 2008 | Toshiba Qosmio G25-AV513 Notebook
Smeg 24 in. DWD612SS Built-in Dishwasher Logo
87 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
