Question about Tascam Audio Players & Recorders
Machine comes on but will not function in any mode- record, rewind fast forward or anything. Do these recorders operate with a rubber band that can rot over time that works thke transport?The recorder is in excellent shape and went from working perfectly to not at all like the old record players used to do.
  • Tascam Master
  • 1,267 Answers
Some of them have mode or Mechanism belts that with lack of use will get soft and stretch. It all depends on what model you have as it is not stated.
Posted on Apr 04, 2013
robotek
  • 1512 Answers
SOURCE: Luxman DAT Recording problems
If the tapes you are using are "tight" it may be causing both the drop out and rew problems. Always a good idea when you buy fresh recording media to ff then threw it through to ensure that the tape is layered flat. they can tighten up in transit sometimes in shipping from manufacture. The unit will need some service work done also. A head clean could also help with the drop out. Use a Chamois tipped head cleaning tool to do thisusing iso alchol only AND A VERY GENTLE APPROACH. The drum heads themselves are very small and VERY FRAGILE!! Easily broken if you do not clean the correctly. Take it to a vcr/video camera tech for a clean and service of the tape path.
Posted on Jan 29, 2008
  • 79 Answers
SOURCE: Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Posted on Mar 21, 2008
  • 79 Answers
SOURCE: Tape cassette deck - tape speed too fast in reverse mode only
Be sure the pinch roller behind the capstan is moving into place like it should. Otherwise, the take-up drive will pull the tape through faster than it should.
Grubhead
  • 5487 Answers
SOURCE: Error F03
I suspect that only one capstan works, The belt driving it might be broken or something else on the drive.
Posted on Jan 27, 2009
Grubhead
  • 5487 Answers
SOURCE: Reel to reel tape recorder hum
Try replacing the Electrolytic Capacitor(s) on the power supply. They will be big value anywhere between 2,000UF and 6800UF. But capacitors of this type are notorious for causing hum, any on the deck could do it!
Posted on Apr 07, 2009
I have a Tascam 488 mk II that will rewind and fast forward, but will not Play or record. Does anyone know a solution to fix this problem?
Check too make sure that the tabs on the cassette itself are there if they are gone place a piece of tape over them, then try recording again. It may be a belt issue open the unit and see if all the belts are present cassettes usually have 2 or 3 separate belts one controlling the fast forward and rewind and another for record and play more than likely this is the issue, If so belts for these units are obsolete try searching science and surplus magazine catalog they carry a variety of large rubber band / belts you may get lucky and find one there good luck I hope this helps you
Mar 31, 2015 | Tascam 488 MKII Portastudio
Why will the Pioneer RT 707 not work in playback mode?
No it is the same motor for both functions. Just check does the record/play switch operate or move when you operate the record function? I have a hunch that is the problem it may also be that the switch contacts are dirty or worn.Try to play a recording you made on another machine if it does sound and play on the other machine then the problem can only be this switch. Some more upstairs decks do have separate amplifiers for play and record .Nakamichi. Studer Revox Tandberg Uher and the such comes to mind These are those machines offering "Off tape" recording monitor. Then it will sport three heads and not only two I hope this gives clues where to start looking for problems
Sep 01, 2014 | Audio Players & Recorders
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
During transcription, when you release the foot pedal, the tape automatically rewinds a little so you can resume easily. This no longer happens with my machine. I have tried several foot pedals, but the...
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
dictationmall
Nov 01, 2011 | Panasonic RR-830 Desktop Cassette...
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VCR won't rewind
Soution #1 get nice but cheep VHS " rewind " macine.
2nd. Some machines have a special rubber wheel in the center,between the left [ take up or rewind ] & right [ play\record ] assemble. VERY diffiult to repair if u don't know what u are doing.
3rd. Find & REplace EVERY rubber band that u find in the machine.
Oct 18, 2007 | Sansui VHF6010 VHS VCR
46 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
