Question about HP LaserJet 1600 Printer
I have a one inch streak down the middle of my printed page on my HP laserjet 1600 printer
  • HP Master
  • 1,719 Answers
Streaks (thicker lines) indicate faulty PCR Roller which is located behind the green drum inside the cartridge. As the printer has 4 cartiridges, you have to identify the faulty one. You may replace the cartridge or get the PCR Roller changed by a professional.
Let me know if any further clarification is required. Hope this helps!
CreatuiveTECH
Posted on Nov 14, 2010
Testimonial: "Thank you, your solution was right on the money. It was the Cyan cartridge."
  • 2,296 Answers
There are a few things you can do to try and fix this. First thing would be to check the toner level, sometimes when the quality of prints drops, it's because of low toner, even the streaks. If the toner level is ok, you will have to clean the printer and the drum kit.
My hp color laserjet 1600 leaves blue streaks on all the copies how do i clean the unit to stop this?
please refer to the link below. I have read up on the cleaning sheets mentioned above and it seems that they either work or they thoroughly jam up your printer
HP LaserJet 1600 Printer Print Quality Defects
Sep 17, 2014 | HP Color LaserJet 1600
I have an HP Laserjet 4, quite old, and it has developed a very prominent streak almost straight down the middle of the page. Staples told me to clean the drum, but my manual doesn't even seem to mention...
Put paper in the manual feed tray. That's the pull down door in the front.
Print something. As the page gets fed 3/4 of the way into the printer, open the top cover. Pull out the toner. Look down at the paper. If you see the prominent streak, you probably have a bad toner cartridge. If the streak is not there, check the fuser. One of the rollers is bad.
While you have the toner in your hand, you should see a flap that is the entire length of the cartridge.
Put you thumb on the flap and pull it down. You will now be looking at the drum.
If you see the prominent streak, that's your problem. See if you can clean it with a soft lint free dry cloth. If the streak comes back, the rubber cleaning blade is probably bad. Replace the toner cartridge.
Feb 07, 2011 | HP LaserJet 4 plus Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
When printing there is a streak that runs down the center of the page ... even when there is no image being printed. Also perveusly to this problem we have had PCL XL errors come up in the middle of a...
try performing a hard reset by holding go and turning on the printer.....otherwise you may try to download the current firmware from hp and install...
Aug 08, 2009 | HP Color Laserjet 3550 Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Streak down the center of the page
The streak is most likely the toner or the fuser
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top or front to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the defect on the page the problem is most likely the toner cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 25, 2009 | HP LaserJet 2840 All-In-One Printer
Printing streaks
Most Printers that are laser have a transfer roller or transfer belt. If you have replaced all the drums this can often be the problem.
Feb 06, 2009 | HP LaserJet 2840 All-In-One Printer
Toner splatter and faint double image
replace the toner cartridge or get the cartridge refilled as its about to empty .
Dec 09, 2008 | HP LaserJet 1020 Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
HP LaserJet 1600 Printer Logo
577 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
