Question about Kenmore Dryers
Have a kenmore heavy duty electric dryer model number #96588210 it just makes a humming noise when you turn it on
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 14, 2010
What size is the kenmore model number 11064852400
Maybe Sears can provide dimensional data.
Dec 01, 2013 | Dryers
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Kenmore heavy duty dryer
its a rear felt kit you can order and install on the rear of tub itself , give complete model number ill look up see if its available
Mar 16, 2008 | Kenmore 63102 Electric Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
156 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
