Question about HP Mini 1000 Netbook
My netbook was being charged and I tripped over the cord and it broke the charger and the place where it was being charged....what do I do?
    Guru:
  • 832 Answers
Hello there!
Try to reconnect if its still working or charging. If not, you can buy an original charger adapter for your HP mini netbook.
Regards,
fossildude
Posted on Nov 14, 2010
Charger
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 | Nabi 2
Tablet wont charge
Have you tried another cord/charger? Has the AC jack been damaged due to pulling on the cord while plugged in? Does it work on AC? perhaps the battery is dead?
Apr 26, 2013 | Lenovo Lenvovo IdeaPad S10-3 06472BU...
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
My netbook charger wont chanrge properly. I have to play around with it too charge. At some places like if i putit down it might charge but then again if it is moved abit then it wont charge. I have to...
This is caused by a faulty DC jack on your motherboard. The solder holding the pins from the jack to the motherboard break and when you wiggle it just right the solder is contacting the board.
Most repair shops will charge you at least $100 to fix this.
Repair options are A. Re-solder the DC jack on, this requires dis-assembly of the netbook B. DC jack has broken pins and it is generally possible to replace the jack unless it is epoxied to the motherboard then it's on to C. C. Replace the motherboard.
A is obviously cheaper.
Aug 05, 2011 | Advent Netbook
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
If the charger cord moves a tiny bit it would stop charging, so I ordered a new charger & it still don't charge. the charge lights wont come on the computer @ all.
Its going to be a problem with the power jack on the motherboard where it needs to be resoldered to the motherboard, or an issue with the motherboard itself.
May 06, 2010 | HP Mini 1000 Netbook
Unablt to plug the charger cord into phone
See if its ddamaged from where you charge the phone. you might be able to bend it back into place....
Aug 14, 2009 | Motorola Mobility RAZR V3
Power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Jan 05, 2008 | Magellan RoadMate 3000T GPS Receiver
HP Mini 1000 Netbook Logo
79 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
