Question about Dell Dimension 4600 PC Desktop
On startup i recieve primary drive not found press f1 to continue
  • 656 Answers
This is the fult of your haeddisk check the hardsk power conected properly change your id e connector and replace with new on when the power is on place your hand on the hard disk and feel the harddisk is working
Posted on Nov 14, 2010
On startup it reads port4 no device port 5 no device drive 4 not found drive 5 not found press f1 to continue
You computer is not able to find any boot device i.e., hard drive CD or DVD drive or USB. Suggest running Diagnostics to narrow the problem.
Here is a link to your models service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-e520_service%20manual_en-us.pdf
Select Advanced troubleshooting and follow instructions.
Feb 15, 2013 | Dell Dimension E520 PC Desktop
Computer running slow
I'd say the bigger problem is it is having problems reading the HDs. That will affect everything it does since it will constantly try to fix that. Obviously, disconnect and reconnect every connection between the HD and the motherboard. Also consider replacing the cables. If still dead your hard drives may have gone bad.
Dec 04, 2011 | Dell Computers & Internet
My dell d2400 will not boot up, I get the primary drive 1 not found, strike f1 to continue, f2 to run the setup utility
when the operating systems was setup on your hard drive, the incorrect partition was set. this causes that screen to appear. more often people will choose that way so that you may have full advantage od a smaller hard drive. this will not affect the performance of the system in any way. the fact that you have to hit the f1 key on startup is just an inconvenience.
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
My Friend just received a cleaned T21 from her workplace. When I try to boot it up I get the following: Initializing MBA. Pres Ctrl+Alt+B to Configure... Managed PC Boot Agent (MBA) V 4.12 UNDI Initialize...
try clicking on this link and choosing Master Boot Record Repair.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-56102
Also, have you tried
Step 1. Make the DVD drive the first startup device in the startup sequence using
the following procedures:
a. Shut down the operating system and turn off your computer.
b. Press and hold the F1 key, and then turn on the computer. When the logo
screen is displayed or if you hear repeating beeps, release the F1 key. The
Setup Utility program opens.
Note:
If the Setup Utility program does not open, shut down the
computer, wait approximately five seconds, turn on the computer, and
then immediately press and release the F1 key repeatedly until the Setup
c. Use the left and right arrow keys to select Startup from the main menu.
From the Startup menu, select Startup Sequence and then press Enter.
d. From the Startup Sequence [Primary] menu, do one of the following to
select the DVD device that you want to use as the first boot device.
Note: When selecting your DVD device as the first boot device, be aware
that internal DVD drives are listed as IDE CD. If you will be using a
supported external DVD drive as the first boot device, select USB
CDROM in the steps below for your choice of DVD device.
v If your choice of DVD device is already listed as the first boot device,
continue with step 2.
v If your choice of DVD device is listed in the startup sequence as any
device other than the first device, select it and press the Plus (+) key
repeatedly until it is displayed as the first boot device. Continue with
step 2.
v If your choice of DVD device is listed as an excluded device, select it
and press the X key one time to add it to the startup sequence. Then,
select your choice of DVD device from the startup sequence and press
the Plus (+) key repeatedly until it is displayed as the first boot device.
Continue with step 2.
e. Press F10 to save and exit the Setup Utility. When the save and exit
message displays, select Yes and then press Enter.
Jul 18, 2010 | Lenovo ThinkPad T21 2647 Notebook
When i start my computer it says press f1 to
This means your hard drive has either failed or is disconnected.
Given the age of the computer it's most likely the drive has failed.
Let me know if there is important data saved on the computer. Otherwise, replace the drive and re-install windows and it should work again.
Crankstart
Jan 08, 2010 | Dell OptiPlex GX150 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Secondary drive 0 not found
Hi there.
Sounds like the boot order has been changed in the bios.
The secondary drive sounds like the CD drive as most laptops only come with 1 HDD installed.
Change the boot order to the primary drive by Pressing F1 during startup when the ThinkPad logo is displayed..
Once in the bios change the boot order, save and exit, the computer will restart and boot from the hard drive, when you get into windows check to make sure that the CD rom recognizes CD/DVD's.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | IBM ThinkPad T20 2647 Notebook
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
119 people viewed this question
Alun Cox
