Question about EliteGroup ECS AMD690GM-M2 Socket AM2 Motherboard
Can i USE A 20 PIN POWER CONNECTOR FOR THE CG51-GM?
2 Suggested Answers
NetSalem
  • 55 Answers
SOURCE: Replacing a power supply.
You need to connect both 20-pin and 4-pin connector to *********** board. Your 4-pin connector is located between your CPU and a I/O connectors.
If you did it right first time, check if you have anything shorted on your board because your old P/S could go bad for reason.
Good luck!!!
Posted on Jun 20, 2008
What power supply connector will work with the ms8137c motherboard (aka, 20 + 4 pin)
Ahem, you just posted 20 + 4-pin.
That means it can be a 20-pin ATX main power cable, OR a 24-pin ATX main power cable.
Most power supply's now have a 20 + 4-pin power cable.
Use the 20-pin connector, or add the additional 4-pin connector, to make a 24-pin ATX main power cable.
Example.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
In direct answer to your question, however, it uses a 20-pin ATX main power cable.
For additional questions post in a Comment.
Regards,
joecoolvette
Jun 17, 2012 | Matsonic MS8137C Motherboard
Need a new power supply for a soyo mother board Crown model fp-
All you need to know is if your motherboard has a 24-pin or 20-pin power connector. You can just count the pins if you don't know. There connector is located on the motherboard. It looks like this: moondogwst75_3.jpg
So if it's a 24-pin, order a 24-pin power supply. If it's 20-pin, order 20-pin. Hope this helps!
Aug 28, 2011 | Computers & Internet
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
I have unpluged the 20 pin ATX Power Connector on the PTGD-LA motherboard, there is a 24 pin plug, I am not sure where to plug it in. I can only find manuals for the PTGD1-LA which shows a 24pin/24plug.
If the motherboard has a 24-pin socket, you need a 24-pin connector on your power-supply.
If the motherboard has a 20-pin socket, then only 20-pins from the connector need to be connected to the motherboard.
Oct 22, 2010 | HP Computers & Internet
Missing power supply. First, thanks to fredtmccoyjr for the boot fix. the BIOS update from A06 to A09 actually allows me to enable boot from harddisk in the settings, instead of settign a useless tick on...
It was the 1996 to 2000 time frame, that Dell was proprietary with the 20-pin ATX main power cable, and the matching connector on the mobo. (MOtherBOard).
Standard 20-pin ATX main power cable, and it's corresponding connector should work, then add the 4 power wires that are missing, in a separate connector.
To expound:
View this standard 20-pin ATX main power cable, and it's respective connector,
The power wires should be in the same place as your P3 units.
(Match the color codes.
Use the lock tab on the 20-pin ATX main power cable connector, to base where the pins are.
Pins 1 though 20. Match the color code of the wires to the pins, and use the chart to compare)
Here is a view of a standard 24-pin ATX main power cable, and it's respective connector, so you can see what power wires are missing, from the 20-pin ATX main power cable connector, that are present in the 24-pin ATX main power cable connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the missing power wires, and what pins they line up with.
The P4, or also stated as the 4-pin ATX +12 Volt power cable, uses two Yellow (12 Volt) wires, and two Black wires, (Ground)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Since you don't have the male connector, be sure to orient in your mind where the Yellow (12 Volt) wires go, and the Black (Ground) wires go, by looking at the lock tab on the side of the female connector, on the motherboard, and comparing it to the photo.
Transfer this info, to the P4 connector you are going to make.
Where to get the power wires you need? Connect to any extra 4-pin Peripheral power cable wires, or splice off of ones that are in use, is one suggestion.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The links given are near the middle of the page. Scroll back to the top. Left-click on any power cable connector, that you wish more information on.
More info,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll to the bottom of the page, and look at the chart under the heading -
24-pin ATX12V 2.x power supply connector
(20-pin omits the last four: 11, 12, 23, and 24)
One more link,
http://www.smpspowersupply.com/connectors-pinouts.html
Lastly Dell Support > Optiplex GX260 > Service Manual,
http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
Just in case it's of any use.
Have questions regarding what I have stated, or need more clarification of anything I have stated, simply post in a Comment.
Jul 06, 2010 | Dell OptiPlex GX260 PC Desktop
Motherboard has a 24pin connector for the power supply, but the connector on the power supply has a 20 pin connect? How do I connect it correctly
i presume that is a pentium 4 or newer motherboard. you will need a power supply that has at least one or two of the small four pin connectors as well... generally if it has that the extra four pins slides onto the 20 pin connector on one side and that makes up your 24 pin connection.
Sep 10, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Hercules switching power supply 500 wat max
yes 20 pin connecter power supply is ATX(advance technology extended )power supply and old which was low watt and 24 pin is EATX (enhaunced advance technology extended) power supply is new and high watt so 4 pin connecter can be detached from 24 pin connecter and can be fitted in 20 pin connecter
Oct 18, 2008 | Guillemot Hercules Dual Fan ATX 450W Max...
Good luck!!!
Jun 20, 2008 | EliteGroup K8M800-M2 Motherboard
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
EliteGroup ECS AMD690GM-M2 Socket AM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
