Question about ASUS Computers & Internet
Suggest Hard drive for ASUS K8N Motherboard - ASUS Computers & Internet
    President:
  • 2,340 Answers
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Posted on Nov 14, 2010
I need vga driver
Hi, try the following site for your vga driver, you need to scroll down the page to pick your operating system:
http://www.easydriverpro.com/driver-update/motherboard/asus/k8n-dl/k8n-dl-windows-7.html
Oct 05, 2010 | ASUS K8N-DL Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
ASUS K8N MB On board audio doesn't work. I've verified that correct settings in BIOS but signal is not making it to the plug for Line Out. I just installed SP2 so I'm going after new drivers next. Any...
Check FP_AUDIO pin settings. FP_AUDIO is located just below the CD AUX. See page 1-6, Motherboard layout.
There should be a jumper over pins 9 and 10 and pins 5 and 6. This is the default setting chassis rear MB audio output.
See page 1-22.
Unfortunately the audio chip is soldered to the motherboard. Most newer Asus MBs the audio chip is not soldered and can be replaced by calling Asus.
Asus manual; http://dlsvr04.asus.com/pub/ASUS/mb/sock754/K8N/e1868_k8n.pdf
Link to Asus site, K8N; http://www.asus.com/product.aspx?P_ID=zigzffr75jWJ7j2y&templete=2
A possible work around would be to disiable the AC'97 in the bios and add a PCI audio card.
Cheers'
Mike
Feb 04, 2010 | ASUS K8N Motherboard
Computer freezes
The cause of the freezing, or locking up, of your computer, is due tosome either corrupted or missing files. And more specifically, missing orcorrupted registry files. These are the files which tell everything on your howit is suppose to work. Basically, they are configuration files. And if thesefiles get corrupted, or messed up, it can wreck havoc.
Jan 11, 2010 | ASUS K8N-E Deluxe Motherboard
Asus k8n-e when xp strat loading the sytem reboots automaticaly
There are two Asus K8N-E MB models;
http://www.asus.com/Search.aspx?SearchKey=K8N-E
Chances are there was a problem during the installation of windows XP. Or there is an issue with your hard disk drive. During boot up, press the F5 key every 2 seconds. Windows Advanced Option Menu will load. From the list highlight, Safe Mode with Command Prompt & press enter. Type the command, C: space fixmbr & "press enter". Wait a few seconds for fixmbr to run.
Than press ctrl+alt+delete to reboot your system. If windows still restarts you will need to reinstall windows XP. A Fresh install is preferred. Running windows repair can make matters worse. Every hard disk drive manufacture has software to setup their drives. Example: If your hard disk drive is made by Seagate, go to Seagate’s web site & download their setup software. Download SeaTools for DOS now!
http://www.seagate.com/www/en-us/support/downloads/seatools/
Instructions are included on the site.
Here is the link for Samsung; http://www.samsung.com/global/business/hdd/
For Western Digital;
http://support.wdc.com/product/download.asp?lang=en
Use the manufacture’s software to setup your hard disk drive before installing Windows XP.
Cheers!
Mike
Oct 07, 2009 | ASUS K8N-E Motherboard
SATA Configuration
They are independent sata configurations so you should be able to. Sounds like fun. Good luck.
Dec 24, 2008 | ASUS K8N-DL Motherboard
Can an internal sata hard drive be used on the K8N-E Deluxe motherboard?
Yes it can! You can install up to 4 SATA drives and 4 IDE drives in the system. If you don't have any SATA power cables on your power supply, you can get a "Molex to SATA" adapter to install it.
Otherwise, you're good to use SATA.
Oct 24, 2008 | ASUS K8N-E Deluxe Motherboard
ASUS K8N-VM mother board win98 drives
Try going to the Asus website and look for support for your MB drivers and Operating System.
If there is no longer any Win98 support for your MB then I suggest a fresh computer and more recent software for less hassle!
A ten year old OS indicates to me that you might be stuck until you go with the flow!
Cruel but true.
Hopefully the recent cheap prices for computers pre-installed with Vista or XP will persuade you.
Feb 06, 2008 | ASUS K8N-VM Motherboard
Computers & Internet Logo
147 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
