Question about Asrock 775Dual-880 Pro Motherboard
Cabel connect problem on the bord power sw reset sw hdd led connecting pins ???? i don't have a plan of the bord
  • 1,719 Answers
Please refer to the Product user manual. You can download it from the following link: -
http://europe.asrock.com/manual/775Dual-880Pro.pdf
Hope this helps!!
CreativeTECH
Posted on Nov 14, 2010
Motherboard User Manual For SiS965L?
SiS965L is a chipset designation, not a motherboard model number. That said, most motherboards do label the header pins for the front panel connections on the motherboard, though they are a bit small and sometimes are not adjacent to the pins themselves. The Power Switch and Reset Switch pins are not polarized, and when you determine which they are, the connector plug can be installed on them either way. The Power LED and HDD LEDs ARE polarized. The positive pin is marked with a "+" sign and the Green wore of the Power LED and the Red wire of the HDD LED must be on the "+" terminal.
Nov 09, 2015 | Computers & Internet
FX58M powerSW
thank to answer.
@Jorico no threr is nothing wrote on the mobo (expt fp1)
Aug 19, 2012 | Computers & Internet
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
Int sw
Green and white is normally the power LED connection, as I recall. I may be wrong. Anyway, you need to trace the path of the wires back to the case and see what it's attached to. You normally will have a power switch connection, a hard drive LED connection, a power LED connection, a speaker connection, and possibly a reset switch.
Jun 05, 2012 | ASUS A8N32-SLI Deluxe Motherboard
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Want to connect my mercury PVM7 PRO MB
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
Jul 28, 2008 | Computers & Internet
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Asrock 775Dual-880 Pro Motherboard Logo
178 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
