Question about Samsung HL-R6167W 61" HDTV
I have a DLP Samsung HL-R6167w and it's not working
I have a SAMSUNG DLP model HLR6167w with a problem.
I just changed the light hoping this would fix the problem. When the problem first occurred, I could barely make out the picture, and it was very green and jumpy (but I could still see spider man on TV with the 5 big vertical lines). I called tech supportand they said unplug the TV and plug it in after about 5 minutes. I did that and now it went from bad to worse. No picture at all. I have whiteand black static on the screen that also has a green tint. I have 5vertical evenly spaced lines. I can put the TV on air-antenna, Satelite, DVD, NindendoWii, and the greenish static follows all components. When I hit "menu"on the TV remote, all menu options are crystal clear. Set-up, channel,sound, etc...all perfect picture...Just a problem with the actualpicture on all components. I turned it on again last night and I found more details. The attached picture is what it looks like when it's on. It looks like that for 15 seconds then freezes. When it freezes I can't turn the TV off/on nor navigate through the TV's menu (it freezes also) Then the screen goes black like it's turned off. I look at the back of the TV and the light bulb seems to still be on.
  • 1 more comment
  • Eatsolot
    Eatsolot Dec 04, 2008
    Thank you all for your input. It was infact a bad DMD board. part number = BP94-02084A
  • dstroman Jan 01, 2009
    My Sangsung HL-R6167W just started the same problem that you have discribed. After reading some of the problems that other owners have listed, I'm not sure if I have a bad DMD board or a defective color wheel. How can I make a possitive diagnosis? Any thoughts??? Thanks DStroman
  • Eatsolot
    Eatsolot Feb 12, 2009
    When my digital board was bad, all inputs didn't work and looked the same. The TV menu looked perfect!!! So maybe that will help you!!!
I had exact the same problem on my HLR6167W and read the suggestions here the past Sunday. There is another suggestion that the cable connecting the DMD board and the light engine could be the problem. I opened the back of the TV and took out the DVD board (just a few screws and several cables) and checked . No sign of burned wire or damage was seen. I reinstalled the DMD borad and made sure tight connections of all the cables yesterday. Miraculously the HD channels came back. I rechecked all the cables (tighten or loose a little bit as needed) and all cannels came back. I don't know exactly which cable was the problem and is not going to find out. I just want to share this so anyone who has the same problem can try this cheapest approach first. The TV is still working well as I am typing this message.
Posted on Feb 10, 2009
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
Posted on Dec 04, 2008
  • 51 Answers
I have fix one with a bad Digital board assy causing the same king of picture in every input. menu as clean as i can be now the other proble may be related to the digital board or you coud have a seconf problem. only time i have seen picture frezzing and no response to remote control its alwas the DMD board assy.
Posted on Jul 03, 2008
Samsung HLR6167W no picture/no sound
So don't. Just retire the set and move on with a newer cheaper better set with warranty.
Sep 12, 2017 | Samsung HL-R6167W TV
Loud hum and then an even louder grinding noise that sounds like something in a fan...Samsung hl r6167w
this is more than likely the color wheel is failing and needs replaced happens on dlp units frequently I would suggest replacing the color wheel should fix the problem
Jan 24, 2010 | Samsung HL-R6167W 61" HDTV
Samsung DLP HL-R6167W - works fine for about 5 seconds then the screen freezes, sound goes out and then goes black then comes back on by itself and repeats the whole process. No blinking error lights.
There are three possible parts causing the problem. First, the Main or Digital bd is bad, Second, the DMD bd is bad. Third the Color Wheel is bad. You need a trained Samsung tech to have a look at it.
Jul 12, 2009 | Samsung HL-R6167W 61" HDTV
Problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Samsung Model HLR6167W
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
Feb 19, 2009 | Samsung HL-R6167W 61" HDTV
Samsung HL-R6167W set turns itself off
sounds like the digital main board, seen this before
Jul 18, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HL-R6167W 61" HDTV Logo
1,220 people viewed this question
Henry  Thomas
Henry Thomas
