Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
STATIC! I just bought the G Track for my Mac and when I record acoustic or voice tracks i get a bad amount of static sound. Ive tried adjusting every thing i can though.
  • 5 more comments
  • Anonymous Jun 19, 2008
    the static is so loud that when i record...it is actually louder than that of what im actually recording!
  • Anonymous Jul 10, 2008
    I am having the same Static problem during playback.  This is my 2nd G-Track.  I returned the first one because of the same problem.  I noticed another gentleman was experiencing STATIC while using a MAC. Any additional info is appreciated!  Thanks.
  • Anonymous Aug 13, 2008
    Hey guys! I've got the same problem. Because of the direct monitoring you don't hear the noise directly. After recording you'll find out that your recording is WORTHLESS! I brought back my G-Track and with no further problems i got a new one. Yuhuhh! So, no... It does the same thing. But what's accactly about the static thing? Can we change a driver setting or something? That thing is so easy that it's not possible to set anything than the volume and things! Am i right? A solution for the guys who hear only mono: set the mic to mono ;) An record in mono (1 channel). When you are recording more than your voice, set it to stereo. (Set input to channel 1&2 (stereo) too. Explaination: You don't need to record in stereo, when there is nothing in stereo. For example Garage Band makes it stereo automaticly when in is setup to mono. When you're going back to the shop because the noise faillure while using a mac, then ask for another, but no G-track. It simply doesn't work well! If it does, let us know how!!
  • ddblakely Oct 16, 2008
    I have the same problem with my newly purchased G-Track,  plus when i make a voice recording, it records in stereo but when i play the track back, it plays back in mono
  • Monsieur O Nov 25, 2008
    Same here : distorision arise here and here using the G track. Seems to be a Mac issue. OK. but where is the solution ? :)
  • Anonymous Nov 28, 2008
    It worked with my PC by i get static after recording for a few seconds on my mac.
  • rotey6 Feb 08, 2009
    I've tried a whole bunch of things - creating an aggregate device, trying to output through a line out cable - all to no avail
I found this on the Apple Website...
http://discussions.apple.com/thread.jspa?messageID=8274095
This may fix it for you...
Ok, I may have found a solution. (Leopard 10.5.5, fwiw)
The problem, according to some people in a different forum, may be related to the clock source of the USB box.
To fix this, I went into Apps/Utilities/Audio Midi Setup. In the Audiomenu there is an entry "Open Aggregate Device Editor". Click that.
In the dialog, click the + button at the bottom of the list, which was empty on my machine.
It will add a new device and in the bottom pane all the sound devicesin your computer will show up. Only check the ones you want to use (USBaudio). Then use the Clock radio button and select one of the USBdevices as the clock source (I used the output).
Click Done.
Now set your default input and output to "Aggregate Device".
That fixed it for me. YMMV, as always.
Posted on Nov 17, 2008
It is being suggested in Apple Support forum that the static is the result of problems with Apple Core Audio software, rather than the G-Track mic. People using any variety of mics, mixers, interfaces are running into loud static when using their macs with 3rd party audio equipment. I would not abandon the G-track immediately, but try out your set up with other equipment (preferably another USB mic) and see if the static is still there.
Posted on Nov 08, 2008
  • 1,512 Answers
Hi philltl89
If it has been doing this since new, there is probably something wrong with it. I would return it to the place you purchased it from and get it changed over.
regards
robotek
Posted on Jul 04, 2008
  • Graeme Ross
    Graeme Ross Sep 16, 2008
    If you have ongoing problems with the gear, just return it to the store of purchase and request a refund. If the product has issues with mac's, then it isn't much chop. Should not be your problem. Many people are experiencing this problem. If they are not receptive to your request, ask them to sort out the problem for you. If they cant, REFUND
I had the same problem intermittently with two different ones so I say no more.
Posted on Nov 04, 2008
Go ahead and use the usb just for power, but try to plug it in to something other than your mac, like a usb power supply or a PC, and then run a 1/8" audio cable from the headphone jack on the right side of the mic to your audio input on your mac. If you still want to monitor as you record, you can buy a splitter for the headphone jack and run both a set of headphones AND your 1/8" audio cable from that. I've given it some thought, and I think it's better than the alternative of returning it and buying a pre-amp, a good quality mic, and a mixer for $300+
Posted on Aug 15, 2008
Gtrack doesnt work really well with mac.. it does with PC
you can restart your mac, and MAYBE it would fix the static noise, but JUST MAYBE. most of the time, it just doesn't do any good..
and if it does.. the noise will come back soon..
so, i'd say this Gtrack is not for mac..
Have a MacBook Pro and A Shure SM27 but the sound it's too low on Garage Band
hello paola go directly in your mac and open properties of the mic and adjust as you like obs this is making tests with the mic connected
yours antonio
Dec 26, 2013 | Shure SM27 Professional Microphone
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Tascam234 /casset tape-4 track,
clean the heads, make sure the tape has no edge damage
Feb 02, 2010 | Tascam 2488 Portastudio Multitrack...
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
Many Problems with Samson G-Track or not?
Hi.  I dunno if yur using pc or mac but with a mac yu need to adjust the mic settings on the comp. For the static its probably your set up or as i said in another guys problem, the usb cable given with it is **** so try using another one from a printer or wtv to see if that makes a difference for you. Also if you are recording just through the mic i find that it seems to only work well when the input is on line and not inst/mic. Hope this can be of some help. Its a great piece of kit once you get it working well.. Goodluck
Jan 16, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Bad Static on the Audio
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
May 16, 2008 | Logitech QuickCam 961464-0403 Webcam
Static on my mbox system
Well it all depends on what program you are using to record your music you will need to activate the noise reduction filter. or lower the volume on your mic but not on the program. Therefore your mic will not pick up any noise in the background and you will still have the same music quality.
Feb 11, 2008 | Digidesign Mbox 2 Barebone
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
1,407 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
