Question about GE Profile JTP56 Electric Double Oven
I have a built-oven oven GE MODEL NUMBER JTP14WDBIWW. when I push on either the bake or broil button a code of F-4 comes on blinking How can i fix this problem. Darrell Bentley dbc3211@aol.com
    President:
  • 1,891 Answers
Only to stop problem .. replace the oven tempt sensor . now if double oven repl top sensor and if the problem still go on repl bottom and then the E O C electronic oven control ..this is the clock . the code states that the ofen sensor is shorted . and some times this short is in the wiring between the sensor and the clock . hopt this will help mm feed back pls ..
Posted on Nov 14, 2010
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
GE oven bake igniter is bad ?
Yes, it should work fine to swap them. (fortunately the bake and broil igniters are often the same part number on GE gas ranges, as as opposed to many other brands) Of course now you broil will not work, but you should be able to get your oven going again.
Jul 15, 2009 | Ovens
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
GE JKP27WP1 Oven Won't Work
Hi Cyrep,
You can fix a suggested fix at the following link:
www.fixya.com/howto/h155060-dreaded_f7_error
Even though you are not getting an error message, they are sometime stored in memory and have to be repeated a number of times before they show up in the display. I have shared this fix with over 1300 folks and most report success. I hope that it works for you too. Please let me know at hutchipop@yahoo.com.
Regards,
Charlie
Oct 15, 2007 | GE JKP27 Electric Double Oven
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
GE Profile JTP56 Electric Double Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
