Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf541 Hi, Washer would not drain have removed all hoses and pump and cleaned it all out - washer now starts, fills so far then warning lights flash to inform me pump filter is blocked - but I have cleaned it all out- do I need a new pump or is there another problem? Thanks for your help
  • markmilner Jun 26, 2008
    Changed the pump - bought a new one for £26.00 from e-spares on the web easy to fit (hotpoint spares are free for 5 years but the call out is £90.00!!) Thanks for the advice
    Genius:
  • 1,028 Answers
Ckd to be sure pump is operating in drain/spin feel pump housing for vibrationn from pump spining if pump not runing or huming ckd voltage to pump with wires removed.. voltage 110? pump probably bad ck for loose impeller they have been known to come loose from motor shaft..no voltage? ckd wiring at control bd last resort bad control bd..good luck
Posted on Jun 19, 2008
My hotpoint washing machine is showing error code F05
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved.
Hope this helps... Please post back for further assistance.
Daniel
Apr 18, 2011 | Hotpoint Washing Machines
Hotpoint ultima wt640 am getting a flash code f-05 clothes still wet appears not to spin
Hi Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps... Daniel
Mar 26, 2011 | Hotpoint Washing Machines
Hi our hotpoint wf541 starts its cycle as normal but doesnt spin and the mini load and reduce crease buttons flash as well as the on/off button, any ideas of how i can fix this thanks.
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
Dec 08, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Daniel
Aug 30, 2010 | Washing Machines
My hotpoint aquarius washing machine wont pump out the water
HI.
You need to check the pump filter.
Remove lower rear panel of washer.
Remove large black hose fastehed to bottom of drum
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Check drain out let hose is not blocked.
Please rate my solution/.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hi could anyone help me please..My Hotpoint WMA52 keeps flooding
It is not draining properly, or overfilling due faulty pressure switch.
Try cleaning the filter first.
Remove large black hose onto bottom of drum.
Remove hose onto pump, and check for obstruction here and in the pump.
Hope this helps.
Dec 07, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint wf541 will not finish cycle it wont do a final spin then all the ligts start to flash how can this be fixed
Possibly a blocked filter.
If no filter at bottom front of washer then you need to remove lower rear cover of washer.
Remove l;arge black hose fastened to drum.
Remve and clean filter inside hose.
Remove hose onto pump, and check for obstuction or blockage here as well, and look inside the pump.
If all o/k, and it still does not spin, then it could be for one of several reasons.
Hope this helps solve your prob.
Thankyou
Nov 26, 2009 | Washing Machines
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
269 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
