Question about Sony Playstation 3 (PS3) Console
Playstation 3 for europe
I intend to buy a playstation 3 and to use it in europe!
Do you have o model made for europe (working in 220V instead of 110V)
please reply at:
  • ovidiupetcu Jun 18, 2008
    please reply at:
  • 65 Answers
All the machine manufacture for Usa work on 110 volt 60 hz and the format is Ntsc.You should check availability on line about region Format like NTSC-PAL -PAL2 SECAM and which country are using the same, and make sure the hz is 50.Most of the new Game system support Dual Voltage But not the Ps3.You need to let your seller check on the machine tag to make sure everything is correct like 220v 50 hz.
Posted on Jun 18, 2008
Hi need a battery charger for Europe 220V for the Model 784000 01a klippers, Where do I buy this!
Hi most oster replacement spares are available on our website anything not listed just contact us.
Feb 23, 2014 | Oster 76076-010 Hair Trimmer
I buy My playstation 3 in u.s the power supply is 110v 1.5A. In my country the voltage is 220. Can i use 220v 150watts transformer
The playstation 3 is dual voltage, meaning that as long as you have the right cable (plug for the wall socket) it will run 100 - 240v.
I believe the only exception to the universal power supply is the PAL 60GB PS3 (CECHC01) model. That power supply APS-227 is not compatible with voltages under 220V.
Jan 19, 2014 | Video Game Consoles & Games
Will my BES800xl espresso mechine (canadian version) work in Ukraine running on 220v? I also have a Juice & Blend BJB840xl and want to know the same thin. Would a high wattage bump up transformer wirk...
Hello, if in canada you have 110V in europe you will have 220V so, you need to find out if next the plug of your devices you have a switch that you can change between 110V to 220V. That will help otherwise you can burn the device.
Nov 22, 2013 | Breville Coffee Makers & Espresso Machines
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Hi I have GE Microwave (model no JES738WJ02) which has suddenly stopped working from yester day ... the problem is when I am starting it,the inside light gets on and the inside dish is rotating properly...
The easiest way to fix a problem at m.w. ovens is to check out if the 220V (Europe) volts feeds the transformer. You must remove the cover, put a glass of water inside the oven, turn on for 3 minutes and measure the tension that come to transformer.
Don't try to measure the transformer output, the tension is very high ~2400V !!!
If at the transformer input there are the 220V (Europe) but the oven still don't heat, the magnetron (m.w. generator) is burned out and must be changed.
Nov 14, 2017 | GE Microwave Ovens
I bought a game inported from japan but when i played, it wont let me due to a region pattern , and i dont kno what that mean
Hello there,
Video games, just like DVD, have regional restrictions placed on them. If you buy a game from Europe, you will only be able to play them on consoles designed to work in Europe. This is the same for Japan, America, Australia, etc. Unfortunately, there is no legal way for you to be able to play a Japanese bought game on an American system or vica versa.
Here is some more information on "Regional Lockout."
I hope this helps. Thumbs up if you think so!
May 02, 2011 | Sony PlayStation 3 40GB System
Does Keurig manufacture a coffee brewer that operates on 220 volts?
They have started to sell them in England, with 220 v.
The Keurig K140.
Oct 14, 2010 | Keurig B70 Coffee Maker
Dryer timer counts off to fast
The only thing that I can think of is that you are using a dryer intended for Europe in the US. While they both run on 220V, the timer motor will be specific for the frequency of the country. The US uses 60 Hz. Europe uses 50 Hz.
To keep the explanation simplistic, your timer motor expect 50 electric (frequency) "beats" per second but instead is getting 60 beats per second. Your clock is turning an extra 12 seconds every minute.
Sep 22, 2008 | Kenmore 63942 Dryer
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Sony Playstation 3 (PS3) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
