Question about Home
I am looking for detailed instructions on rehanging a 3 panel glass sliding shower screen door. House is 10 to 15 years old. Rollers are little blue rollers - two that are screwed to the top corners of each panel. However, they do not slide/glide properly and keep falling off the top metal runner. The right panel is fixed, the middle panel is the problem, the left seems to operate okay. I have tried balancing them, etc but can't get the right combination. Are there any written instructions out there somewhere?
  • donnar800 Nov 17, 2010
    Yes, the shower doors now hang in a balanced fashion and don't fall off each time they are moved. Thanks muchly.
  • 10,865 Answers
Hello donnar. Here is an excellent step-by-step set of instructions. http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
That said, most doors do install in similar fashion once you find a set similar to yours. I am a wee bit concerned that your set may have rollers that are on their last legs, which would result in their not sliding or gliding as they should. Use some penetrating lubricant, such as WD-40 to loosen them up and lubricate them. The difficulty with all of these items that are ten years old or older is that the parts are usually nonexistant. Like you, I enjoy the challenge of keeping things u and running way beyond their normal life expectancy. In fact, I am still using a hot tub that is 19 years old! Joe
Posted on Nov 14, 2010
I have a shower glass door which has three doors. One of the door always comes off when I slide d open
most shower doors are held in by the rollers some are adjustable if yours arent check to see if the spring is still holding wheels out firm if not spring probably broke
Dec 12, 2012 | Home
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
Where can I find shower door rollers for a maax shower door? Thanks.
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
Mar 05, 2011 | Home
The inside shower door is uneven, making it come of the hinge after moving it more than 4-6 inches.The metal attachment holding the glass is lower than the other ones.How do I get it even so it slides...
The top rollers should have adjustments on them to bring the door to horizontal as it swings accross the track.
Start with door in the middle and adsust by seinging it to both sides.
Dec 02, 2010 | Basco Deluxe Sliding Glass Shower Door /...
Shower door off track
It's usually best to take the OUTSIDE door off in that case; and start from the INSIDE, then do the OUTSIDE. The track wheels MAY be reversed on IN/OUT, so watch how they hang in the track. When everything is off, it's a great time to scrub out all the "yuck" that grows down in there. Once that's all cleaned out, rehang the INSIDE door and get it going smoothly, then the OUTSIDE door. You're all set then.
May 08, 2010 | Basco Deluxe Sliding Glass Shower Door /...
Broken rollers on shower door
The rollers for most shower doors are a stamdard size and are available at most hardware stores. The Bigbox stores might even carry rollers for you specific make and model.
Feb 25, 2010 | Aqua Brass Prestige Shower Kit #2 AQUA...
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Home Logo
768 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
