Question about Iriscan Express 2 Flatbed Scanner
How to download IRIScan driver - Iriscan Express 2 Flatbed Scanner
My computer is windows 7 64 bit. will the iriscan Express 3 work on my machine?
Contact the manufacturer of the software for the definitive word regarding this matter. U do not want to buy and then have to return.
Oct 31, 2015 | Iriscan Express 3
Cannot re-install software
Sounds like the uninstall process has caused a rigistry error, presumably you are using windows.
Try a registry cleaner. Try CC Cleaner it is a decent product that cleanses gently and may restor your registry, you maust remember to back it up though, in case the restore goes wrong..
The application can be downloaded free online, try cnet or softpedia
Alternatively, you can try rolling bak your OS with windows recovery, to a time when the software was not installed ?
Good Luck
Jun 11, 2015 | IRISCan Mouse Executive 2
No cd rom on laptop to download software for iriscan mouse
The driver software is not available online so here are your options:
1. contact I.R.I.S. directly, explain your situation and ask them for a downloadable version. - http://www.irislink.com/c2-2444-189/I-R-I-S--Support---Technical-Support-Contact.aspx
2. Take the CD to another computer and transfer to USB stick
3. Take the CD to another computer and email yourself the driver (could be a little large)
4. Take CD to another computer and copy to a network location
Most of these contain having access to another computer - I suggest that you contact the company directly.
Apr 09, 2014 | Iris Inc IRIScan Mouse Scanner USB
Won't install iriscan express3 drivers on windows 8
Not all software works on all operating systems. This is just a fact of life. Check with the manufacturer if an update has been released or will be released for windows 10 ..... they may have one. You could always stay with windows 7 or even a dual boot setup so that you can have 7 andd 8 booting up the preferred OS at startup
Good Luck
Dec 21, 2013 | Iriscan Express 3
I lost my serial number.
I WOULD TRY CONTACTING THE COMPANY AND EXPLAIN YOUR PROBLEM, IF YOU REGISTERED YOUR PRODUCT WHEN YOU FIRST BOUGHT AND INSTALLED IT THEY SHOULD HAVE A RECORD. YOU MIGHT ALSO TRY DRIVERS.COM THEY MAY HAVE A FULL VERSION ON THERE, ALSO SEE IF THE COMPANY WHO MADE YOUR SCANNER HAS SUPPORT FOR THE PRODUCT,MOST OF THEM DO.
Dec 31, 2011 | IRIScan Executive 2 Flatbed Scanner
I have lost the drivers of my "IRIScan" 600dpi. Where can I find them?
hi
go to below link you will get your drivers
http://www.irislink.com/c2-1741-189/Drivers.aspx
vote me if find your solution
Oct 13, 2010 | IRIScan Executive 2 Flatbed Scanner
I need a windows 7 driver for an iriscan portable scanner
Check this page out for info from Iriscan on Vista support and drivers: http://www.irislink.com/c2-988-189/vista-support.aspx
Feb 05, 2010 | Office Equipment & Supplies
Where do I get a Windows 7 driver for the Iriscan Express 2?
The IrisScan will work with Win7 32-bit. This from both the Microsoft Compatibility Center and the manufacturer's web site. In that case, just plug in your scanner and the correct driver should load (go to Windows Update on your computer to finish the installation, if needed). However, if you need a 64-bit driver, you are currently out of luck. They only have a 64-bit XP driver (no support for Vista or Win7 in the 64-bit version.)
I hope this helps.
Dec 20, 2009 | Iriscan Express 2 Flatbed Scanner
Iriscan Express 2 Flatbed Scanner Logo
410 people viewed this question
Top Iris Office Equipment & Supplies Experts
xalint1
xalint1
Are you an Iris Office Equipment and Supply Expert? Answer questions, earn points and help others
