Question about HP L1906 19" LCD Monitor
I have a colored vertical line from left side across the screen appears when monitor is turned on and data signal sent to it , first it was comes and disappear by shaking or moving or pressing on the bottom of it and now it is continues , please help
  • 44 Answers
Most likely the display is defect, you can try to change the settings in your computer and put the display in 1024x768 and 60Hz but I think it will not solve your porblem. You have to send it for a repair or buy a new one.
Posted on Nov 14, 2010
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
My ViewSonic monitor is having an issue with blurring lines. Anything on the left or middle of the screen blurs to the right in a faded color, extremely noticable when I open MS Paint and fill the left...
This is a tipical flyback defect circuit, the lines can 1st appear on top/bottom of screen, then can increase to center. Send monitor to repair center, for check and repair. You can test with a tv test signal.
Dec 11, 2009 | Computers & Internet
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
Dell 2407WFP Monitor losing signal and having colored line artifacts
also suggest trying a newer monitor if possible. most of the time it is just setting refresh rate alittle lower. good luck.
Nov 03, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
HP L1906 19" LCD Monitor Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
