Question about Dishwashers
I need assembly instructions for Delta faucets
    Genius:
  • 3,422 Answers
Can you please let me know the make and the model no.
Posted on Jun 18, 2008
  • Priya darshan Jun 18, 2008
    Please CLICK HERE for the instructions.
    If you need anymore help let me know.
    Please don't forget to rate or accept the solution
    Brigadier General:
  • Dishwashers Master
  • 3,614 Answers
  • micromaster
    micromaster Jun 18, 2008
  • micromaster
    Assistance is available
    If you need help while installing your Delta faucet, there are three help options available:
    • Call us at 1-800-345-DELTA (3358), Monday through Saturday, 7 a.m. to 9 p.m.(CST)
    • Click here to chat online with a customer support representative, Monday through Saturday, 8 a.m. to 8 p.m.
    • E-mail us any time - Responses are usually provided within 24 hours.
  • 197 Answers
What model and where did you buy that Delta?
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
Wont fill with water. error E1 faucets is not opened. have water in mains.
Hi
E1 is a leakage error in your dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Dishwashers
Faucet connection
You only need to put back on the steel clamp that fits over the assembly which holds down the shield, the spring, and keeps the 4 ball bearings in place. The ball bearings may be tricky though as they tend to fall out when your putting the assembly back together.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Machine is beeping and a faucet is appearing in the panel
I just fixed this fault on my SHE68m05uc. The fault lets the machine run through any cycle and every ting else was working properly. In line between the fill valve and fill float assembly there is an electro magnetic impeller which is "open" if there is no water flow. the signal goes to the timer control board on the lower right side of the machine. If you Pull the impeller, take an OHM reading across the sensor that is mounted to the side of the impeller and blow into one end. If the measurement changes as it rotates, its good. if its shorted "0 Ohms" its broke. The part was about 17$
Nov 20, 2008 | Bosch Evolution 800 SHE68M05UC Stainless...
Attaching potable dishwasher
Did you remove the existing aerator from the faucet nozzle first? If not, that's your problem.. If you did..then look at the adapter to see if the therad pattern on the end looks like the thread pattern of the aerator you've removed.. If it does.. then you need to install that one.. Sometimes ..you can get them started by rotating it into the faucette backwards a few turns and then rotating it forward until the threads get started properly..after that.. just tighten it in place.. Hope that helps !
Aug 18, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Just got the Haier hdt18pa portable dishwasher
You have to buy an adapter for the faucet that allows the hose to hook up. You an get it at any hardware store. It's easier to get a dishwasher installation kit and just hook it up permanently.
Jul 17, 2008 | Haier HDP18PA Stainless Steel...
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
I can't get the faucet adapter to stay on
Yes usually you will need to repair because bracket inside wore down it cost you around 40.00 and is very hard to find after alot of reserach I found a local guy to help me and it works great , Take off retainer clip and thing will come apart both spring and bracket then you pull four clips out and replace all of the following
Jan 04, 2008 | Kenmore 24 in. 17842 Free-standing...
Faucet Attachment Leaks
The o rings need to be replaced and plumbers lube added on the interior of the connection point.
May 15, 2007 | Kenmore 17259 Free-standing Dishwasher
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
