Question about NEO MP3 Player
Hi. I can't use my NEO mp-01f !! When i attach the device is having problem -can't recognize the device. I moved the USB cable in all my usb hols but nothing .. How can I fix this problem?
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
Hi My hard drive lacie minimus super speed usb 3.0 1Tb is recognized by windows 7 then after a few minutes it disconnects. Donato
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 20, 2011 | LaCie 2TB MINIMUS HD USB 30 301967 USB 20...
Vista will not recognize my MP-C582's USB device. Could you please help?
Hello
This happaned to me a couple of times before, i am not saying this is the cerrect way to solve this, but it works for me every time.
Plug the usb device into one of the USB ports at the back of the computer case, it should work then. Hope this can help.
Kind regards
Anrdea
Nov 06, 2009 | Coby MP-C582 MP3 Player
USB not recognized
Change the usb cable and then plug. Make sure you had installed proper software before connecting the device.
Oct 16, 2009 | Cell Phones
Pinnacle Moviebox Deluxe - Error "USB Device Not Recognized"
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU!
Feb 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Computer does not recognize coby mp705
you know the hold button on mp3 player? while connected to the computer, move it to the left until it says hold and it stays there... or if its already on hold move it to the right until its stuck on start symbol
or move it to the right and left vs left or right..
it worked after i played with it for a while...
now if you wait 30 seconds it may or may not reappear :o
Jan 06, 2009 | Coby MP-705 Digital Media Player
Windows xp wont recognize usb connection from rave. Is there a driver I need?
If you're using the retractable usb cable that came with the player, replace it. I had the same problem. XP recognized that there was a device, but couldn't open it. I was getting a "Driver not installed" error in device manager.
Jun 08, 2008 | GoVideo Rave-MP AMP512 MP3 Player
NEO MP3 Player Logo
56 people viewed this question
Top NEO Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NEO Audio Player and Recorder Expert? Answer questions, earn points and help others
