Question about QMark MCM1503 Utility Heater
Brand new heater is dead right out of the box. Help!
  • 395 Answers
Return ithe heater to the place where it was purchased and request a replacement under warranty.
Posted on Nov 14, 2010
Windows dont work
lost operators, manual.
sun roof, can be 3 things
fuse
jammed
motor. dead.
3 fuse boxes (iml looking on online fsm)
fuse box 3 contains, fuse 32 and 45.
fuse 32 runs , "IG2-SIG-15a)
roof, and
quote:
Radiator fan relay #1
Radiator fan relay #2
Radiator fan relay #3
A/C compressor relay
Seat heater switch (Driver side)
Seat heater switch (Passenger side)
Sliding roof unit
Blower motor relay
unqout
id bet it is not the fuse. see why? the blower, would be dead.
fuse 45: all is only S/R that is the label too.
this box is long and skinny
with 3 relays on left
and
2 fuse top
11 fuses, in horz middle.
10 fuses on bottom row. fuse 29 bottom right.
fuse 39 center right
and top 2 are 51 and 50 , left to right
Nov 26, 2013 | 1995 Jeep Grand Cherokee
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Brand new heater won't start. Transformer buzzes. Power is good. led doesn't light. 3A fuse at bottom of circuit board keeps blowing as soon as the power to the unit is turned on. Problem?
There is a definite problem here with a dead short, honestly I would return the heater to where ever you purchased it from. To be brand new it should be out of the box and plug it in maybe a little programming and instant heat. Hopefully you are not to far away from the purchase place.
Jan 03, 2011 | Heating & Cooling
NO DISPLAY
what type of heater are we talking about no display could be many a reason, the common is lost power to display either bad connections or dead batteries, so if you can give us heater make or at least gas, air con, electric or what not it would help with brand make and model then can help, but no display usually means no power unless its a lcd display or something like that that is broken so a bit more info and you'll get more help and pointed in right direction
Nov 17, 2010 | Honeywell Heating & Cooling
2001 dodge grand caravan ex 3.8 does not turn over
Try checking relays in the fuse box under the hood. If all checks out ok, check timing belt/chain.
Mar 19, 2009 | 2000 Dodge Caravan
QMark MCM1503 Utility Heater Logo
35 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
appman67
appman67
john h
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
