Question about Miele G2142 24 in Builtin Dishwasher
Miele dishwasher g1142sc large light flashing. pump on all the time. you have take plug out to stop it
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
gwshaw71
  • 83 Answers
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I have the same dishwasher and it will not INTAKE water. This unit does ****. So much for a "smart dishwasher".
Posted on Apr 07, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele dishwasher starts pump runs then stops and inlet drain light flashes
Here is a manual for servicing it.
http://ww2.justanswer.com/uploads/smitty1486/2011-11-25_043923_g600__800_miele_service_manual.pdf
Jan 13, 2013 | Miele Dishwashers
Hi, my Miele G1142SC makes noise at startup
Mine is doing the same thing. I tried running a finish cleaner though a cycle. I did nothing I was about to do the same thing again when it just stopped doing it. What did you end up doing?
Jul 20, 2010 | Miele Dishwashers
Intake/drain light flashes and the dishwasher won't run
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Mar 07, 2010 | Miele 24 in. G892SCU Plus Built-in...
The intake/drain light is flashing and we cannot turn on our Miele G 8481 dishwasher. How do I fix this problem?
Either the drain or drain screen is plugged up, or the pump is leaking, loose, or broken.
Feb 10, 2010 | Miele Dishwashers
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher...
Hi eaglesblue,
I'm Harvey the Master Plumber.
Your problem is: Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher pump is working fine.
Please take no offense but a plumber is not the same as an experieced appliance installer. Any way, your mate may have done just fine but the water line is clogged or he failed to flush the line before hooking it up and you may now have a clogged solanoid valve. Did you run the d/w a couple of times before he left? Did you confirm it working then and now it's not?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Miele Dishwashers
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele G2142 24 in Builtin Dishwasher Logo
435 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
