Question about Cameras
How do i get flash to work on i.t.works ds 30895 please
Hi there, i have a premier digital camera ds-5057, how do i turn on the flash light?
hi i have a camera premier ds 5080 the flash dont work how do i put it on?please help.
Apr 17, 2010 | Optimus DS-5080 Digital Camera
Ds red light flashes briefly
Is your DS old? If your battery is charged 500 times, it won't work anymore says Nintendo. Anyway, get it fixed by Nintendo!
Oct 09, 2009 | Nintendo DS Console
R4i Or R4 Ultra?
my advice is do not get any r4 chips plus trhey ellegal
Jul 12, 2009 | Nintendo DS Lite Console
R4 card with games works in my DS. But wont work in sisters DS. Why????
Hmm, depends what DS your sister has.
The R4 is known to work in both the original DS and the DS lite.
However the new DSi has a block and requires a new type of flash cart.
Even with new firmware updates the R4 will not work on the new DSi.
You'll need to find a cart for the DSi, these are usually rather inexpensive.
Also about the firmware, the type version of your cart might not be supported by the latest update. The fact it stops working in all DSes means that something was wrong.
I hope this helped out a bit.
Mar 20, 2009 | Video Game Consoles & Games
Could not find [dsystem] folder
Do you use a flash card,like R4 Ds or the G6.If so then the files on the disk maybe corrupt.Just format your Micro Sd card that is in the flash card then put the firmware on it.If you dont know how look on youtube.
Jun 26, 2008 | Nintendo DS Lite Console
Nintendo ds
You might have loosened a wire. Either take the ds apart and reconnect it yourself or send it in to nintendo for service.
Jun 11, 2008 | Nintendo DS Console
NINTENDO MESSED UP
If you flashed your DS Lite this is the classic problem. A DS Lite NEVER EVER NEEDS TO BE FLASHED!!
What you can attempt to do is remove the Bios from your non-working console and clear it using unflash or a similar utility. Do a Google search and you will find the instructions.
You will need a working DS lite to correct the problem.
Thank you, Bob
May 08, 2008 | Nintendo DS Lite Console
Nintendo DS Adapter
You'll need an adapter that works in your country. If once you have that it still does not work then you probably need a new battery. Without a working battery you won't be able to play the DS even if the charger is plugged in. The charging light will flash and go out if the battery is bad.
Mar 26, 2008 | Nintendo DS Lite Console
Nintendo DS lite-help neede!Please!
Hi
Tamsin
Try taking the battery out of the back using a small philips screwdriver and wiping it it worked on mine
If this does'nt work it might be a new battery.
hope this helps
godfather21
Mar 18, 2008 | Nintendo DS Lite Console
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
