Question about Sony Playstation 3 (PS3) Console
Error code 8002a548 - Sony Playstation 3 (PS3) Console
Error code 8002A548 will not let me sign in
https://support.us.playstation.com/app/answers/detail/a_id/3948/kw/8002A548
  • Step 1: Check on the status of the PSN.
  • Step 2: If the PSN is online, use the PS3 Internet Browser and try to visit any website. If you can, your Internet service is running correctly, go to the next step. If you cannot there is an issue with your Internet service. Click on the type of connection below for troubleshooting steps.
  • Step 3: Try accessing the PlayStation Store. If you can, this means that the PS3 can connect to the PlayStation Network and the issue is with the game. Try contacting the software publisher for additional assistance.
  • Sep 27, 2014 | Sony Playstation 3 (PS3) Console
    Error code 8002a548
    Here are the official troubleshooting steps from Playstation for that error code: https://support.us.playstation.com/app/answers/detail/a_id/3948/kw/8002A548
    Basically it's saying you're having network problems...
    Are you using your PS3 over WiFi?
    If so, try plugging a computer cable into the back to see if the problem stops.
    Make sure you do a network connection test in your PS3
    These might also help:
    Try resetting your modem/router and disconnecting other devices from your network. (they may be needlessly sucking up bandwidth.)
    Also, try shutting off the media server connection. (Settings > Network Settings > Media Server Connection > 'Disable'.)
    Dec 01, 2013 | Sony Playstation 3 (PS3) Console
    I have an error code in the install operation tell me how to fix it
    Common PS3 Error Codes and required Network Ports.
    Additional PS3 Error Codes:
    80010514 - Dead BD lens.
    80010516 - Dead BD lens (happens at different occasions, code above is more common).
    80710092 - Connection error (usually the connection is dropped), you will be signed out of PSN.
    8002AD23 - Unidentified error (cause unknown), happens in Burnout Paradise (when game starts) and sometimes SARPBC.
    8002A227 - PSN account suspended.
    8002A212 - error returned by the PSN servers during authentication (invalid version).
    80029945 - Can't playback burn BDr movie (error in picture above)
    80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
    (workarouns is to transfer files to ps3 via TVersity)
    (added 24th Sept 2007)
    80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card) (added 15sept2007)
    80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them) (added 04-sept-2007)
    80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured (added 30thAug2007)
    8003041F - An error occurred during the copy operation (using media server) (added27aug2007)
    80010006 - An error occurred during the start operation (added 22aug07 - corrupted folding install)
    80010007 - An error occurred during the start operation (added 17aug07 - during disc swap tests)
    710102 - DNS Error; No DSN server available.
    8013030 - System Error due to failed update download
    80010001 - Major Error , Game ability stopped
    80010017 - Can't start Blu-ray Game
    80010510 - Will not play hard drive games - Cause unknown
    80010516 - An error occured during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
    80029023 - Exchanging Key Information exchange has timed out
    80029024 - "Cannot Obtain an IP address".
    80029564 - Downloaded Game will not install - Cause unknown
    80030920 - An error occurred during the copy operation. The file may be corrupt or there isnt enough memory. Try copying data from original source.
    80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Pre
    80031601 - Error Creating Account
    80130203 - PS3 connects to internet but not to network - Typically means that the required ports are
    80410418 - DNS Error
    80710016 - Playstation Network is down.
    80710092 - "An error has occured. you've been signed out from the ps network" -(connection dropped?
    80710101 - Conneciton error
    80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
    80710541 - The connection to the server timed out. press the x button to repair and restore default"
    80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
    81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
    8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
    8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
    80028EA5 - Unknown?? User cannot connect to PS3 network. Sony told the user to send the machine in.
    80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn.
    Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
    80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automactic,
    80028f17 - Ps2 disc Boot Error , An error occured during the start operation; Ps2 game swapped using the eject function and then play pressed quickly -Backup ps2 game inserted again
    80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
    80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
    80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
    80029C68 - Corrupt data usually on external device
    8002A10D - Unable to Add friend in XMB
    8002A4A6 - Cannot load game to play online
    8002A515 - Error Signing in
    8002A548 - Unable to remain logged in - either to game or server
    8002A705 - Unable to connect to server/host. Check router port configuration.
    8002a71a - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
    8002b241 - DVI has no audio
    8002F994 - To many people downloading the update just sit back until the morning around 5am - 11am and you should be able to get it.
    8002F997 - Trying to Update the Firmware, copying to a file and installing from a USB drive falied".
    8003051E - Game will not Save
    8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
    WPA or none
    8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
    8013030F - Check Router Page, SSID Broadcasting possibly off.
    8013030F - Access Point not detected
    80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
    807101FF - An error occurred during communication with the server. This is a DNS error This is a DNS error
    8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the
    80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
    80710D23 - Turn the PS3 off for a bit (30 minutes give or take) with the power toggle (not standby mode)
    80029513 - Copyright Violation when attempting to install game
    8003200D - Server side issue, much like the trophy syncing problems.
    8001050F - System Clock Error.
    8002A227 - You account has been banned, either temporary or permanently, (Check here for reason why you may have been banned).
    80029780 - Unable To Activate System - You have reached the maximum downloads for an unactivated system. This will not affect systems that are already activated on your PSN account.
    80010002 Invalid argument.
    80010003 Invalid syscall number. A lot of the addresses in the syscall table at 0x2EB128 point to a function that only returns this value.
    80010009 Operation not permitted.
    8001002B Filesystem mounting failed.
    Aug 18, 2012 | Sony Playstation 3 (PS3) Console
    Sony PS3 ERROR CODE 80710092?
    80028EA8 - Seems to mean unable to authorize isp account details
    here are some of the ps3 error code that might help you in the future..
    Complete PS3 Error Codes:
    0710102 - DNS Error; No DSN server available.
    80010006 - An error occurred during the start operation (corrupted folding install)
    80010007 - An error occurred during the start operation (during disc swap tests)
    8001000B - it happens when trying to establish wireless connection
    80010017 - Can't start BlueRay Game
    8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown
    8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
    8001050F - Hardware failure. Cannot update firmware or connect to internet.
    80010510 - Will not play games installed on the hard drive
    80010514 - Possibly reading blu-ray disc problem
    80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
    80023101 - Unknown
    80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server
    80028EA5 - User cannot connect to PS3 network
    80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.
    80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,
    80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again
    80029024 - "The attempt to obtain an IP address has timed out".
    80029501 - connection
    80029509 - When the PSN network is down for maintenance.
    80029513 - This content cannot be accessed on your account (80029513)
    80029564 - Downloaded game will not install
    80029751 - warhawk wont start but eveything else seems ok
    80029945 - Can't playback burn BD movie
    80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )
    8002A10B. It shows up when I try to view my friends trophies, profile etc.
    8002A524 - connection
    8002AD23 - Unknown
    8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.
    8002B241 - DVI has no audio.
    8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
    8002F994 - Too many people downloading the update (download it later on)
    8002F997 - Can not update XMB firmware
    80030001 - Deleting messages from inbox
    80030517 - It seems to happen when you copy large media files.
    8003051E - Game will not save
    80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)
    80031150 - "Setting information is corrupted.Press the x button to repair and restore default"
    8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none
    8013013D - connection
    80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
    8041040F - Communication with the server failed. A dsn error has occured.
    80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"
    80710101 - Connection error
    807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error
    8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection
    80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode
    Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
    Ps3 slim error #8002a548
    CALL SONY TOLL FREE NUMBER ,,,IF NOT READING DISK ITS THE BLUERAY DVD DRIVE,,MEANING THE LAZOR LENS IS BAD ,,WHAT GIG BITE IS IT ...
    Dec 14, 2010 | Sony Playstation 3 (PS3) Console
    Perticular error code has no solution
    Hello Mr Gizmoboo18
    8002A548 Unable to remain logged in - either to game or server
    Oct 07, 2009 | Sony Playstation 3 (PS3) Console
    Error has occurred you have been signed out of playstation network error code 8002A548
    an error with update version 2.40 meant users worldwide were having the same problem
    Jul 04, 2008 | Video Game Consoles & Games
    Setting up wireless connection on ps3
    u have to set your IP on your modem settings to static IP
    Nov 17, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    168 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
