Question about Murray 38 Lawn Mower Blade Belt '90'96 37X86MA
I need to find gearbox fill plug on victoria murry rideon mower1996...
How much and type of gear box oil do I have to use in my mk4 golf, 1.6 litre engine transmission( gearbox)
Mark 4 VW Golf Manual Gearbox
VW has a specific blend of gear oil for that gearbox that you need to buy from VW dealer Parts department. If you cannot get it there, you can use a 75w-90 fully synthetic automotive gear oil .
The capacity is about 2.2 quarts (US) so ensure you buy enough.
If you are changing the gear oil yourself the vehicle must be level. Completely loosen or remove the fill plug first, to ensure you will be able to refill it ,before you remove the drain plug and drain the old oil out of the box. You will need a fluid pump in order to pump the new oil into the box and you keep adding the gear oil until it begins to run out the fill opening. It is full when it stops running out the fill opening so it is important the vehicle is level when you are doing this service.
You will need a good 17 mm Allen key to remove and refit the drain and fill plugs in the gearbox.
The fill plug is on the front left side of the transmission case while the drain plug is on the bottom by the dog bone.
Apr 18, 2016 | Cars & Trucks
Rideon was under flood idrain engine oil do i have drain gaer and biff oil as well. and what oil do i replace gear oil with.
Yes, you do have to drain the gearbox and diff as well, because the oil in them will also have water in it. For the gearbox, use SAE 90, Gear oil. The diff will use the same oil. Don't forget to clean or replace the spark plug, and clean the Carby.
May 02, 2015 | Mtd Yard Machines 38-Inch 12.5 HP...
How do I check the level of a manual gearbox on a 2002 Peugeot 607 hdi
you will need to consult a manual, some gear boxes need a measured amount of oil in them and the only way to measure is to drain and measure, others have a filler plug on the side of the box and these type are filled with oil until it starts to trickle back out ,don't over fill
Mar 02, 2015 | 2002 Peugeot 307
How to fill gearbox with oil
  • 1
    Locate the fill plug. This is typically on the top of the gearbox. If you are having problems locating it, follow the speedometer cable down to where it connects to the transmission; the fill plug will be near the cable.
  • 2
    Remove the fill plug.
  • 3
    Place a clean funnel in the fill hole and fill the gearbox with gear oil. Check your vehicle specifications to see how much is needed. Re-install the fill plug when done, hand-tighten and then torque the plug down with a socket wrench one turn.
    Original Launch X431 Master
Mar 15, 2013 | Cars & Trucks
Murry 10hp 8/30 rideon can select gears but wont engage
inspect the drive belt from the engine
Jun 30, 2012 | Garden
Nissan primera gearbox oil
Remove drain plug.
After fluid drains, install drain plug.
Remove fill plug.Fill with gear oil untill oil runs out of fill hole.
Install fill plug.
Nov 12, 2011 | Cars & Trucks
I Need to top up my gearbox oil and I don't know where the filler part is on the gearbox.
Are you referring to the front diff,rear diff or transfer case? On any of them gear boxes there is a fill plug and sometimes a drain plug. The fill plug is the plug closer to the top of the gear box. Just turn it out and wipe the metal shavings off it and fill the gearbox with the required gear lube until the lubricant just barely seeps out and that's the fill level. Plug the gear box again and your done. This is standard with gearboxes.
Regards, Tony
Apr 20, 2011 | Isuzu Pickup Cars & Trucks
When i squeeze my auger control, my snow thrower makes loud noise and kills my engine. what kind of problems do i have?
Hi
First check the belts that they didn't run off the pulleys and get jamed. Check the idler/tightner pulley see if it spins freely. Check that nothing is jammed in auger. Try to turn auger pulley by hand if it does not turn or is noisey you have a problem in the gearbox.
Sam
Jan 07, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to change the manual gearbox oil on Toyota Yaris 2008? (The locations of the gearbox drain and fill in plugs)
drain plug on the bottom of the gearbox,fill plug on the side of the gearbox and you only fill it till it just starts to run out and put plug back in should be 24 mm plug
Sep 20, 2009 | 2008 Toyota Yaris Sedan
Range Rover Vogue 1989 model 3.5l V8 fuel injected, with Automatic gearbox. I need the type of engine, gearbox, transfer box,and differential oil to be used on this vehicle. As well as the...
use 15w-40 for the engine, ATF for the gearbox and 80w-90 for the diffs and transfer box. engine and gearbox have dipsticks for the levels, the diffs and transfer box have removable plugs for level checking, fill until the fluid comes out the level plug.
Mar 09, 2009 | 1989 Land Rover Range Rover
Murray 38 Lawn Mower Blade Belt '90'96 37X86MA Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
