The drier in my indesit washing machine will not warm up even though it still turns-whats happening?
    President:
  • 1,462 Answers
Check dryer element is not open circuiit. also, on the dryer manifold there are various stats, one of which is resettable (has a small button in middle) press this and check if now works on dry. if this solves the problem but it reoccurs, then there is probably a blockage in the air duct
Posted on Jun 19, 2008
Indesit washing machine does not turn on
If it's tripping breaker, there is a wire shorted somewhere.
Nov 07, 2017 | Washing Machines
I require the operating manual for my Indesit washer/drier model WILD146
Try this site.#
WWW.INDESITSERVICE.CO.UK.
In the menu on left click on---- Indesit user manuals
You should be able to find what you are looking for here
Apr 05, 2010 | Washing Machines
I would like a manual for an IWDE7145 washer/drier
You can try diplodocs.com. This may have what you need. If not, it has links to other sources to find one.
Hope this helps you.
Oct 28, 2009 | Washing Machines
The drum wont go round
either motor faulty or carbon brushes worn down take motor out and inspect
Jul 08, 2009 | Washing Machines
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
The washing machine turns on;but the dial keeps turning round on its own,even though i have removed a blockageof a 1p coin and a small hair bobble.any advice please?
Your pump may have been damaged and could need replacing.First try resetting on all three black dots and then try just a spin to see if resolved
Nov 07, 2008 | Indesit Washing Machines
Re washing and drying
Hours? It sounds like your machine has a problem.. Have you tried clearing the filter on the outlet after the drainage pump? The Indesit only has a 1200 spin speed so it's not the most efficient drier anyway (rated B for spin efficiency).
Personally I dislike Indesit as they release some models which do not permit replacement of the bearings because the innner and outer drum assembly are crimped/pressed together during manufacture. Instead of replacing bearings and seals (At most about £35.00) you would need top buy a complete drum assembly at about £125.00, and throw away a large lump f stainless steel. Presumably Indesit want you to throw the entire machine away, and to buy a new one. Not a brilliant idea in my opinion, as it is unlikely that a frustrated ex Indesit owner will but an Indesit as a replacement, and that sort of wastage (bearings last around three years in regular family use) makes a complete nonsense of energy efficiency ratings. The cost of manufacture and disposal over a three year usage period will have a massive carbon impact in comparison to the energy efficiency savings even of the most efficient of machines.
The planet can't afford to buy cheap machines and then thropw them away.
Apr 28, 2008 | Indesit W 123 Front Load Washer
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
