Question about Refrigerators
Temperature in freezer doesn't come down below freezing point
My frige is a top-freezer model of frigidare crown series, made in 1997. It worked fine until two weeks ago when I noticed that icecream and pops stayed half melted. Icemaker stopped making ice.
I did these things in response:
Turned the temp control to colder in the freezer first, no improvement, temperature being just at the freezing point.
Turned the frige temp to colder, no improvement, either, temperature remaining 45F degrees or so.
Cleaning the back doesn't seem help.
What else can be done to bring down the temp in the freezer?
Thank you.
ye
  • CaptainMary Jul 03, 2008
    Our freezer on our Frigidaire Crown series is keeping everything cold, but it is frosting up. The refrigerator does not seem to be working at all. Any ideas. It is in the basement and is clean under and behind the unit. No dust or debris anywhere near.
    Thank you,
Searching on line, I noticed some similar problems addressed by technicians and customers. But their diagnosis was consistent: call the repair guy. They believed that the solution to the kind of problem I had was between "dump it" or "pay a big lump of dough to repair. So we replaced the old one.
Posted on Jul 09, 2008
Hiw di I set the temp to the correct temp
turn freezer to mid point and try fridge on 3.5 as a starting point.
Keep the refrigerator temperature at or below 40° F (4° C). Thefreezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
press the helpful button and check link below
Fridge temperature guide Kitchen
Jan 29, 2016 | Refrigerators
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
Mar 13, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Model TBX18KMB. Liquids on top shelf often freeze. Also,need to cut electric bills,can Power Saver help?
Turn the refrigerator temp control down try factory setting, usually c on frige and 3 on freezer control. The cold air circulating from the freezer enters at the top of the frige therefor it is usually colder.
Nov 04, 2009 | GE Refrigerators
My RM2852 Is Freezing the food in frige section, what might the problem, be? Does this unit have a defrost switch??
Located in the inside in the rear top of the fridge are aluminum fins. on one of the fins near side of fridge there is a folded aluminum sleve that skides up and down on the fin.
this actualy adjusts the temperature of your fridge. slide up or down to adjust fridge cabnit temperature.
Aug 28, 2009 | Dometic RM2852 Refrigerator
Freezer problems
this particular refrig has only one temperature control which as you know is loated in the refrig section. but temperature isnt your problem. when the icemaker fill tube freezes up like yours has it is generally a sign of a bad icemaker fill valve. the valve seals will go bad and allow water seepage into the line, this seepage will freeze creating a snowball effect freezing the tube. you can use a hair dryer to remove the ice from the tube, and either replace the fill vlave yourself or have it replaced
btw the fill valve is the part that the other end of the fill tube is connected to on the back/bottom of the refrig in the compressor compartment. Good luck and message me back if you have any questions. Thanks Peyton
Feb 24, 2009 | Hotpoint HTS17BCM Top Freezer Refrigerator
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
The freezeer works just fine, but the frige is only about 68 degrees. it is about 100 degrees outside here does affect operation.Frige and freezer have seperate temp adjust.
What is the temperature in the freezer? Anything below 32 degrees freezes water. Make sure condenser coil is clean and that air can flow over it freely. In the back behind a removable panel you will find the condenser. Clean it completely and make sure the fan operates when the compressor is running.. Also check for possible frost on the back wall of the freezer which would indicate a defrost problem. if there is frost there the problem is ether a bad timer, heater, or defrost thermostat.
Jun 11, 2008 | Frigidaire Refrigerators
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
