Question about Dryers
Frigidaire gas dryer, burner lights but gets shut off immediately
I have a Frigidaire Gas dryer, model FSG748GF. It basically has stopped drying clothes. I checked all the venting which is clear. Opened the dryer up and found that the burner lights up fine and produces a good flame, but after about 10 seconds the burner shuts off, but the drier keeps spinning. Almost as if a sensor has told it that the cycle is done or that it is too hot. If I then open the dryer door to stop the cycle and then immediately turn the dryer back on, the ignitor gets red hot, but then just fades and the burner doesn't light. If I wait a couple minutes, I can then repeat the cycle above. Any ideas as to what part is malfunctioning? Thanks in advance. dryer lights , stays on for about 30 seconds then flame dies checked thermostat on drumb and it has no continuity when flame quits continuity when cold seems to be free of lint
    Genius:
  • 1,028 Answers
Ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Posted on Jun 19, 2008
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Gas dyer not staying on, all the light are flashing
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
Jul 09, 2012 | Frigidaire Dryers
My frigidaire gallery heats up but after a few minuts stops
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire FSG748GF Dryer
Frigidaire model # FG01442ESO, is not drying.
I would replace the gas valves on the dryer. They are located just before the igniter on the dryer. Make sure you unplug the unit and turn off the gas before doing this repair. Good luck
Aug 24, 2009 | Frigidaire FGQ1442ES Gas Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
The dryer still runs well, there is no heat and you have to run the dryer hours before your clothes are dry
This could be one of several problems. The most common problem that causes no heat is a clogged duct or vent. If air is not flowing out of your unit due to a clogged vent or duct, it will immediately overheat and shut down the gas burner, in gas models or the calrod heating system in the electric models. Try removing duct, checking for clogs in the duct and at the connector at the unit itself. Then check the vent inside your home and on the outside wall for lint clogs.
Jun 07, 2009 | Frigidaire GLEQ2152ES Electric Dryer
There is heat but not enough to dry the clothes
Remove the connecting vent on the rear and try it.
If that works clean the connecting vent and the wall vent.
If it does not work, replace the gas valve coils.
Mar 28, 2009 | Frigidaire FSG748GF Dryer
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
168 people viewed this question
Top Dryers Experts
