Question about Apple MacBook Air
My cat walker over the keyboard and now everything has changed colour and looks kind of over exposed , like a photographic negative. Does anyone know how I can get it back to normal? Also, none of the top keys above the numericals are working now. Please help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
Go to system preferences, click on the control panel called Universal Access once in there under display it is probably on white on black the setting you should be on is black on white. I'll try and get back to you with regards the keys as I have had this before but can't remember how I corrected it just now. Hope this helps.
Posted on Nov 14, 2010
Bush TV set up colours look like looking through night vision lenses.
Try to reset the unit to factory default settings.
If the TV is under any kind of warranty, return it while you can.
Also, without knowing what kind of TV, Plasma, ect. it is had to pin point your problems.
Hope this helps
Mar 22, 2014 | Televison & Video
Philips 42PFL7962D/12 LCD TV
Try changing the Tcon board, this kind of issue is almost always caused by a bad IC on that board..If you typed in the right model number it may be hard to find this board as I couldn't find one...good luck!
Dec 17, 2017 | Televison & Video
Can you fix the colours of the pictures on the screen of my Toshiba Satellite pro P300. It looks like the negative of a colour photograph. Light colours are dark and black is white. Red appears as blue...
In windows 7 , -
1 Go to the ease of access column in the control panel
2 Then go to the link "Turn on high contrast..."
3 Deselect it if it is selected
If it doesnt work then-
1 press Alt+Ctrl+Del
2 On the lower left corner their would be a button to Ease of Access
3 press it and deselect "Turn on high contrast "
This should work cause i tried it on my own computer
Mar 27, 2013 | Toshiba Satellite Computers & Internet
CAN YOU PLEASE EXPLAIN TO TO ME WHAT IS EV COMPENSATION AND HOW DOES IT WORK
EV compensation is "Exposure Value compensation". The camera contains an exposure meter which determines how much light is on the scene and sets the exposure appropriately. However, this meter does not know WHAT you're taking a picture of, nor does it know what effect you're going for. The best it can do is to assume you're taking a picture of an "average" scene and want it to be of "average" brightness. It does this by assuming the scene is "middle gray," halfway between black and white. Most of the time this works fine, because most scenes are, well, average.
However, this is not always the case. Suppose you're taking a picture of a white dog playing in the snow. Almost everything in the scene is bright white, but the camera doesn't know that. It tries to make the scene middle gray, and the result is that you get a gray dog playing in gray snow.
On the other hand, suppose you're taking a picture of a black cat sleeping on the hood of a black car. Here everything is black, but the camera doesn't know it. It tries to make an average scene, resulting in a gray cat sleeping on a gray car.
EV compensation allows you to override the camera's exposure setting. In the first example, you'd want to add two or three stops (positive EV compensation) to force the camera to render the dog and snow as white instead of gray. In the second example, you'd want to subtract a stop or two (negative EV compensation) to render the cat black instead of gray.
How much EV compensation is correct? Well, that depends on the scene. With a digital camera, you can look at the picture and see whether the dog looks white or the cat looks black. Film photographers take lots of shot, using various levels of EV compensation, so that one of them would come out right.
Mar 19, 2011 | DXG Technology DXG-505V Digital Camera
Looking to replace the cat on my 1999 volvo v70 all wheel drive and the replacement cat does not have the O2 sensor mounted in the middle of the cat. does this make a difference ?
I would find the OEM Cat design.
I know you want to avoid the dealer one
due to cost.
I would think Walker should make it,
check their web site and your local
auto parts.
If you get something different, then
maybe the wires won't reach etc
Dec 19, 2010 | 1999 Volvo V70
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Battery leads
Can You state exactly what the toy is. Maker, Name, model, pictures, year of manufacture. Details help the research process.
But try this...
If talking about a circuit, look where all the solders are, You can sometimes find a solder point that doesn't have a smooth top it will look like something broke off. Find two of these...To tell the difference when you find them which wire goes where, the solder point that traces back to any capacitor ( a cylindrical component with two leads on its bottom that has a black strip down its side noting which lead is negative.) The black wire can be soldered back to the point that traces back to a negative lead. Then the positive (red) will go to the other one.
If this does not help see if you can upload a good quality pic of both sides of the circuit if possible.
Aug 18, 2008 | Toys
LCD flickering / Purple/Green Photos
I'm sorry to tell you, your CCD its death, no human intenvention can fix it, you must replace it, when a CCD fails, it's literally death, you can not fix it, its a very delicated part, and the fail it's some kind of microscopic evaporation or filtration problem, I'm pretty sure that it has no fix. I spend the last year trying to fix mine, but with negative results.
Aug 17, 2008 | Fuji FinePix S7000 Digital Camera
Monitor spaz-mcgee
This is really sounds like a keyboard issue. From your description it sounds like your ?.? key is locked in the active position, note that the key doesn?t have to be down for the contact below to be engaged. This isn?t uncommon, especially with older/cheaper keyboards. A quick test is just to replace it with another USB keyboard, even a Windows keyboard will do for a test. If that solves your problem you can try taking it apart to clean, however, if it?s in warranty I would just call Apple support. If its fairly old I would just bite the bullet and spend $35 for a new one.
Dec 03, 2006 | Apple Cinema 20" LCD Monitor
Apple MacBook Air Logo
51 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
