Question about Toyota Car Audio & Video
MY PZQ60-60040 is showing TELMUTE on the display and nothing works. Is there a fix-it for this?
Telmute on radio screen - no sound
1) test the speaker with DVOM OR VOM, by continuity see the diagram attached..Test all wires connector from oxide, dirty, and continuity
2) if the speaker are o.k the problem is the output of audio IC from your Radio, go to the repair shop TV & Radio .
God bless you
Jul 01, 2012 | Toyota Cars & Trucks
I have the boss BR-900CD and everything seems to work fine but nothing shows up on the screen. It lights up but no data shows up. Thanks
the problem is from the display IC of your unit. You nee to change the display IC for your unit to display again.
If you cannot do it yourself, maybe you should consult an expert to help you have it fixed.
Good luck.
May 13, 2010 | Music
The lcd display is not working properly; is there a source for parts?
the lcd display on three of my moultrie i40s shows nothing anymore, is there anything that can be done to fix this?????
Nov 04, 2009 | Moultrie Cameras
Digital display ford fairmont au 2000
Unfortunately, if it shows nothing at all you will have to replace it. The only serviced part is the globe for the backlighting.
Aug 26, 2009 | Ford Fairmont Cars & Trucks
Nokia 7710 display light on but nothing shows
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Apr 10, 2009 | Nokia 7710
My jvc tv has good sound but nothing showing
if when you turn the set on the display does not light up at all there is a good chance the display has gone, if you ring jvc they should be able to giv you a price of a new dsplay i will warn you it wont be cheap.
Mar 08, 2009 | JVC AV-27530 27" TV
Display shows nothing
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
Also, Please reply back with your brand and model number so we can help you.
Mar 02, 2009 | Microwave Ovens
Motorola Razor V3 Lime Green
this is a very simple problem to fix just take it to a mobile service center and have them correct the issue for you.
Mar 06, 2008 | Motorola Mobility RAZR V3
Car Audio & Video Logo
151 people viewed this question
Top Toyota Car Audio & Video Experts
Martin Clarke
Martin Clarke
wadingriver
wadingriver
Are you a Toyota Car Audio and Video Expert? Answer questions, earn points and help others
