Question about Sub-Zero 661/F Side by Side Refrigerator
Frost on back of refrigerator
It gets frost buildup in refrigerator
  • 1 more comment
  • Sherrae Jul 15, 2008
    I also get frost on the back of my refrigerator which melts at times and drains onto the floor.
  • mameve Jul 18, 2008
    Lots of frozen frost on back of the refrigerator--look like Antartica--thick and frozen solid.
  • cuperken Oct 31, 2008
    Same here. Thick ice forms on the back bottom left back of the refrigerator. The service man has checked the freon level, coils, and replaced the door gasket (it was bad in any case and not part of the problem).
    He also "reprogrammed" the controls per Subzero's instructions.
    Problem persists.
  • Sub-Zero Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFrost on back of refrigerator - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Frost and Ice Buildup
If everything is cooling fine and the frost is not on the back wall but just the floor at the bottom then your defrost drain is stopped up. Remove the bottom basket and clean up the ice on the floor of the freezer. Look on the back wall and you will see some more ice up a littler higher at the back. This is where the drain is. Clean all the ice out from this area too using hot water or a hair dryer. Once you find the drain hole make sure you get all this ice out of it as well. You can take a screw driver once you have melted the ice and gently push it through the drain hole. Once the hole is cleared you should be able to pour hot water freely through the hole. (It is best to turn the refrigerator off while you do this)
Jul 01, 2010 | GE Profile PSS26NGS Side by Side...
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Frost buildup
you need to check the defrost circuit and make sure the heater is working and the unit goes into the defrost mode.
also check and make sure the temp sensor is good
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
Doors won't stay closed!
Frost in the rear of freezer possibly caused by door staying open.  Door staying open possibly caused by frost buildup on ref door track.  Start by making sure the teeth on the freezer track are clear of ice and frost.  This should allow you to shut the freezer door.  Next check the freezer seal.  If it is not completely sealed it it will build up frost. It is also possible that the frost in the rear of the freezer is from a failure in the defrost cycle as the evap coils are at the back of the freezer. If this is the case your refrigerator is probably getting warmer.
Oct 25, 2009 | LG (LRBC22522ST) Stainless Steel
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side Refrigerator
Check for frost on the back wall of the freezer section. If no frost buildup is noted check that the condenser under the refrigerator behind a removable panel in back is clean and that the fan there operates when the compressor runs.
If you have frost buildup in the freezer section on the back wall you have a defrost system problem. These problems are not related to the cleaning ladies work unless some paper or other item may be stopping the fan from turning.
Jun 11, 2008 | Refrigerators
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
THE REFRIGERATOR AND THE FREEZER HAVE QUIT COOLING. HOWEVER THE FAN AND THE LIGHT IS WORKING. WHAT CAN I CHECK
Check the back wall of the freezer compartment for snow or frost buildup. Fan running would indicate that the temperature of the coil which cools is cold. If you find a frost buildup on the back wall you more than likely have a problem in the system defrost circuit. You need a service tech.
Apr 28, 2008 | Refrigerators
My side by side fridge
either you have a leak in the system and your short on gas or there is a frost buildup on the evaporator and you have a defrost problem. either way you need to remove the back of the freezer and check. if it is all frosted over its a drfroat issue. if there is no frost or only a partial frost pattern it is a sealed system leak. check that and get back to me and we can go from there. thanks
Aug 10, 2007 | Frigidaire FRS26F4C Side by Side...
Sub-Zero 661/F Side by Side Refrigerator Logo
168 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
