Question about Bionaire Ceramic Tower Indoor Space Heater
Bionaire bch9221-um tower heater is still creating hot air but I think the fan is not blowing because it is not making that whirr sound that it usually makes and the hot air smells like it is burning on the ceramic heating unit. It happened all of a sudden without warning, just one day it wouldn't turn on and make that sound to let me know it's working properly. There was no signs it was going to give out, and like I said there is still heat but it smells like it's getting too hot and something is burning.\r\n What should I do to get this fixed? Is it best to bring it to a shop like Target (where I bought it from) or something with electronic repairs? How much would this cost me (I don't have a lot)? It is getting cold and I turned it on because I need it!
  • Bionaire Master
  • 2,525 Answers
Hello christillejo,
A total CLEANING works wonders...!!
Check the fan for VOLTAGE... If present & ...
If it is not running... shut it all down... and clean your fan parts with at least 70% alcohol... blow it dry and set it aside while you find your HIGH-GRADE (CLOCK-TYPE) silicone oil...
Put a wee bit (oil) on your freshly cleaned bearing surfaces.
While the FAN might not run a complete 15 to 20 years it did before... this procedure can add years to your FAN'S life-cycle.
In the meantime... check your OPTIONS for an opportunity
appliancepartspros
Search Over 2 1 Million Appliance Parts
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Partsselect
PartSelect Appliance Parts and Repair Help
Carnac the Magnificent
Posted on Mar 21, 2017
2 Suggested Answers
SOURCE: polohunt1@aol.com my bionaire bch9221 120
Mine was doing the same thing. Took it apart and found that the white wire which hooked up from the circuit board to the heating element had burnt which broke the connection...hence no heat....replaced burnt wire and resoldered to heating element...put it back together and voila I have heat once more....still doesn't solve why the wire fried though....
Posted on Oct 30, 2011
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
How to change remote control battery for a Bonaire heater
The remote for Bionaire® 20" Ceramic Mini-Tower Heater with LCD Control uses BUTTON cells (Disc type, 3 volt, CR2025)..
Open the remote as shown in page 4
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-bionaire-ca-Library/default/dw869fb9a8/documents/instruction-manuals/BCH9208-CN_EN.pdf
Jan 12, 2014 | Bionaire BT200RCU Tower Fan
Where to get manual for Bionaire BCH9221-UM Tower Ceramic Heater
I like to know how to change , up or down the thermostat ( degrees ).
Jan 12, 2012 | Bionaire Heating & Cooling
My Bionaire Tower fan is Switching the sitting by itself from 1 speed to 2 speed. is it a defect?
I don't think it is a defect, but you may want ot check with the store.
I have a similar one that starts at a higher speed and switches down to low after a few seconds.
After that I can select the running speed.
Mar 31, 2011 | Bionaire Tower Fan w/ Ionizer and Remote ...
Polohunt1@aol.com my bionaire bch9221 120 volt heater does not produce heat anymore.....i'm thinking that maybe an element within the unit is burned out.
Oct 13, 2010 | Bionaire Heating & Cooling
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Aug 03, 2009 | Heating & Cooling
Bionaire upright fan stopped blowing air
Throw it away. I have come to conclude that Bionaire is a junk brand that does not service their products. I have a bionaire model BCM646 humidifier purchased at COSCO and the water tank broke.
NO! I did not drop it, it just sat in the corner. I have not even used all the factory filters that came with it.
Who would have thought a made in China product (for American idiots) would break and not have replacement parts?
Such a shock considering their fine reputation.
Apr 01, 2009 | Bionaire BT45RC Tower Fan
Heater output goes from hot to cold
It sounds like you have a blocked heater core ( Small radiator that the interior fan blows through to create the heat inside the car), If you can get access to the heater core pipes you might be able to flush it out but usually they need replacing.
hope this help
Jan 15, 2009 | 1997 Land Rover Range Rover
Coolant temperature sensor?????
um...strange ...engine temp reaches 210 before thermostat opens and lets water circulate ..fans go on before that normally..180 or so..hot air from heater going to cold air? strange...could you elaborate for me /us?
Nov 10, 2008 | 1994 Volkswagen Golf
Heating & Cooling Logo
169 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
L Pfaff
L Pfaff
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
