PC Freeze Up or Lock, Up
When trying to open up, or download a web site from an e-mail \Can only resolve the lock up by using the Task Master to end Program, tehn restart the e-mail program - by lock up I mean that the m;ouse does not do any good in trying to change the issue
  • 790 Answers
Hello ledihite!!
Try changing the browser!! may be the browser problem!! And also download ccleaner
from the linked website and clean your comp regularly!!! And please try to rate the premium problem u posted before ... you have to rate the best solution or else it will be credited the expert who has given first!!!
Regards
Smilemaker
Posted on Jun 19, 2008
I cant open my nokia 6120 because someone try to enter incorrect password morethan 5 times and now i cant open it using my lock code
Network unlock having 5 tries ,But security unlock forgot means you can use the master reset code and reset it.You can get the master reset code from the site
www.simpleunlocking.com and reset the incorrect password or security lock.
Oct 19, 2011 | Nokia 6120 classic Cellular Phone
Hello, I am hoping you can assist. I have a CL1000 lock and I am wanting to change the User Code. Unfortunately, when I use the factory set code it doesn't open. I have tried using the master code...
This web page will take you to a "Help" chart for your lock:
http://www.codelocks.us/need-help.html
If you are in the U.K., use this site:
http://www.codelocks.co.uk/
Try going to the "Code change help" chart and selecting the CL1000.
If you cannot resolve your problem there is a phone number listed on the web page that you can call for technical assistance.(714 979 2900)
Good luck--and please provide feedback if this helps!
Sep 01, 2011 | RTO Codelock CL1000 electronic keyless...
I have forget the unlock code wht its master code
First Try it:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
type *#06# on your phone to get it.
or:
The best thing you can do is to go down to a cell repair shop. They will most likely have a special cable that will connect your phone to a computer (PC), allowing all the contents of the phone to be seen. The security code is then easily seen on the PC.
It does not cost a lot to do (here it is done at an equivalent of about USD$10 on a bad day). Some people even build or buy their own cables. There are many schematics on the net
you guys should try this web
http://gleez.com/articles/did-you-know/nokia-secret-codes
http://files.myopera.com/manujha/soft/UnlockMe.SIS
http://www.symbian-toys.com/UnlockMe.aspx
OR:
visit this site for full unlocking http//unlockme.co.uk
Thanks
Aug 20, 2010 | Nokia N70 Cellular Phone
Please let me know how to Operate Function keys on the Key Board (Teclado Intel A27982).
Close F6: Closes the document or the file in the active window. Forward F8: Forwards the e-mail in the active window. Function Lock (F LOCK) Switches between the standard function key commands (F LOCK light on) and the Microsoft keyboard enhanced commands (F LOCK light off). Leave it on or off, or alternate between modes for increased key press functionality. Help F1: Opens the Help system for the active window. New F4: Creates a new document in programs that support this command. Office Home Starts the Web browser and goes to the Microsoft Office Web site. (This is not available on all keyboards.) Open F5: Opens a document in programs that support this command. Print F12: Prints the file in the active window. Redo F3: Cancels the previous undo action. Reply F7: Replies to the e-mail in the active window. Save F11: Saves the file in the active window. Send F9: Sends the e-mail in the active window. Spell F10: Starts the spell checking program in the active document, if the document's program has this feature. Task Pane Shows or hides the Office task pane that was previously displayed. (This is not available on all keyboards.) Undo F2: Cancels the previous action.
Jan 05, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
Microtek Scan Master 5900 hrdware error -3
Code 3 The driver for this device might be corrupted, or your system may be running low on memory or other resources. (Code 3)
Here are some things that you can try to resolve this problem.
Close some open applications
If the computer has insufficient memory to run the device, you can close some applications to make memory available. You can also check memory and system resources, and the virtual memory settings.
  • To check memory and system resources, open Task Manager. To open Task Manager, press CTRL+ALT+DELETE, and then click Task Manager.
  • To check virtual memory settings, right-click My Computer, click Properties, click the Advanced tab, and then click Settings in the Performance area.
Uninstall and reinstall the driver
The device driver may have become corrupted. If the driver is corrupted, uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Install additional RAM
You may have to install additional random access memory (RAM).
May 21, 2009 | Microtek SCANMAKER 5900 Flatbed Scanner
Pc freezing up
There is a strong chance that you got something nasty which keep connecting on the net when you
are using these apps.
I suggest an online scan with Kaspersky and a malware scan asap.
Nov 16, 2008 | Computers & Internet
Problem getting netzero download to download computer says need to close i need to close explorer browser sites but none are open
Please note that I am using Windows XP so Vista may be slightly different but mostly similar.
Press Ctrl+Alt+Del and open the "Task Manager". Click "Processes" tab and check the box next to "Show processes from all users". Look for the file name of the web browser you are using and here are two common web browsers.
Microsoft Internet Explorer - iexplorer.exe (If you close explorer.exe by mistake, Windows XP users can go to "Applications", "New Task", and type in "C:/WINDOWS/explorer.exe" or Vista users can simply log out and log in through the task manager.)
Mozilla Firefox - firefox.exe
If you use a different web browser, right click the shortcut for your web browser and click "Properties". The file name will be after the last slash ( \ ) in the target box. File names usually end with ".exe".
Click the file name when you find it and click "End Process" but before you do, you are most likely viewing this with a web browser so this window (and all other windows for your web browser) will close as soon you end the proccess. This means make sure you finish what you are doing and be ready for it to close.
Aug 10, 2008 | Computers & Internet
Desk top PC- Freeze up or Lock up
HI,
Did you try opening the website in a different browser and see if you face the same problem.Let me know the result.
Goodluck..
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
